ducatipaso.org • View topic - Inlet Manifolds
It is currently Fri Feb 27, 2026 2:42 am
 Post subject: Inlet Manifolds
PostPosted: Wed Apr 06, 2005 10:05 pm
PostPosted: Thu Apr 07, 2005 12:12 am
PostPosted: Thu Apr 07, 2005 11:29 pm
Thanks for the reply Jcslocum.
Subject to my friend checking out the carbs, he lives close to where they are and will check out the Air Screws etc. If he gives the ok on condition then will be getting hold of:
Pair 600 Carbs
Carb Rubbers
Inlet Manifolds
Air Box including Lid
Pair Donkey Ears ?????
bits and bobs of hose's to do with Airbox and carbs
Now which do I go for
the 900SS Inlets
or the 600 Monster Inlets
All the above and choice of inlets for £180 good bad or over priced?
PostPosted: Fri Apr 08, 2005 1:22 pm
PostPosted: Fri Apr 08, 2005 4:44 pm
PostPosted: Sat Apr 09, 2005 10:37 am
in cas you want to custom build an airbox you may consider getting this one so you have one to cut up. The lower part would have to be built new with glassfibre. If you plan too try this, attempt to get the rubbers from the airbox with which the airbox is mounted on the carb.
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... 92580&rd=1
Gerhard
