ducatipaso.org • View topic - Gear whine
It is currently Mon Dec 08, 2025 5:33 pm
 Post subject: Gear whine
PostPosted: Tue Mar 04, 2008 9:04 pm
'88 Paso.
45,000 miles.
In third gear I get a lot of gear whine. I think it is getting worse over time.
What are the options of what it can be?
How serious is it likely to be?
What should I do about it?
SMS
 Post subject: Re: Gear whine
PostPosted: Wed Mar 05, 2008 1:27 pm
Is this at all speeds/rpm??
PostPosted: Wed Mar 05, 2008 2:39 pm
... or under hard acceleration combined with a power loss, then it could be a slipping clutch.
Is it only in 3rd gear ? In the worst case the teeth of your gear are worn and if pieces brake off, this could lead to an engine damage sooner or later.
viewtopic.php?f=3&t=2259
PostPosted: Wed Mar 05, 2008 4:32 pm
Not the clutch-
at all speeds.
the whine follows the rpm with pitch increasing with rpm.
