ducatipaso.org • View topic - Inside original mufflers
It is currently Mon Apr 27, 2026 11:45 am
 Post subject: Inside original mufflers
PostPosted: Fri Mar 21, 2008 2:35 pm
Do they look/function basically like this:
http://www.ducatisuite.com/superbikemufflers.html
with 3 chambers & endcap?
Guess you`ll have to open them att both ends to modify them.
Any knowledge and pics would be appreciated! :)
(Why? Because I like the looks of the original and I`m checking all options.)
 Post subject: Re: Inside original mufflers
PostPosted: Sun Mar 23, 2008 10:23 am
Hi Gert,
I think they'll look that somehow
The 907 canisters are welded. grinding down the weld is not so difficult.
changing the internals can be done also.
But what kept me of doing so is that it is not sure that after the welding you have a muffler like new wirhout any discolourations and deformations. :?
I believe the 907 /'92 had a aluminium liner over de steel canister. In that case you might have the possibility to cover up the weld.
Ducbertus
PostPosted: Sun Mar 23, 2008 10:36 am
I've opened an st 944 muffler to build the prototype I've installed on my dukess, and it was basically done in the same way.
Anyway, shortening the lenght of the internal labirynth might be a downgrade for engine performance!
Have a look in my gallery to see how I solved the problem! :thumbup:
PostPosted: Sun Mar 23, 2008 2:41 pm
PostPosted: Sun Mar 23, 2008 9:04 pm
There's a post titled "sounds good" with some spec about
and the images are in the 750 gallery, #751582... the pic is "inside the 50mm muffler" :lol: :lol:
