ducatipaso.org • View topic - rear fork pivot oil seals
It is currently Sat Dec 06, 2025 7:23 pm
 Post subject: rear fork pivot oil seals
PostPosted: Fri Mar 28, 2008 8:36 am
Hi all,
Can anyone supply me with the measuraments of the rear fork pivot oil seals? (i.d. should be 19 mm. as far as I know )
Local dealer do not stock them (surprise...surprise..), and since it`s my commuter, hate to get them out just to discover they cannot be found... :,(
Thanks,
Eli
 Post subject: Re: rear fork pivot oil seals
PostPosted: Fri Mar 28, 2008 12:39 pm
did you check the last page of the FAQs ?
PostPosted: Fri Mar 28, 2008 1:06 pm
Hi G.,
Actually, I did look. am I missing something? or maybe I wasn`t clear eanogh: I`m talking about the chrom tube that runs through the engine, and enable swingarm movements.
Sorry to trouble you.
Thanks,
Eli
PostPosted: Sun Mar 30, 2008 11:39 am
Eli,
The part you are talking about is the swingarm. Yes it looks like a fork but that's on the front of the bike!
The seal part number is 937831526. This is the seal for the swingarm bolt that is in the engine case. I have a set of cases here and can measure the seal later.
PostPosted: Sun Mar 30, 2008 6:15 pm
Thanks, & sorry for the term mixup..
