ducatipaso.org • View topic - Give your head a shake
It is currently Mon Jun 22, 2026 11:42 am
 Post subject: Give your head a shake
PostPosted: Sun Apr 06, 2008 5:40 am
Hello my friends-
My 750 Paso is shaking its head. I say go straight and its head shakes "no".
Starting at perhaps 60kph, it wants to be unsteady. Perhaps the front wheel is a little bent. These wheels are very soft and even a little impact will bend them somewhat.
But I think maybe there is another reason. have you any ideas as to what it could be?
Thank you,
SMS
 Post subject: Re: Give your head a shake
PostPosted: Sun Apr 06, 2008 6:40 am
maybe it's just unbalanced.
Motorcicle wheels have a "static" balancing, instead of automotive ones and their "dynamic" balancing.
First of all, remove the wheel and have a look to the bearings and to the brakes, then you can go for the "static" balancing...
It means that you need a stand to put the wheel free to spin and just move it for one or two laps...
The heavier part of the wheel will stop in the lower part: try once or twice to find the exact point! :thumbup:
PostPosted: Sun Apr 06, 2008 7:18 am
There also are many reasons, as the rear tire worn, a bad alignment beetween the wheels, a bad regulation of the fork, ...
I think a little bend of the wheel is an unlikely reason.
PostPosted: Sun Apr 06, 2008 2:53 pm
Has any work been done to the bike recently??
Adjust the rear shock? Raise the rear height? Drop the front?
PostPosted: Mon Apr 07, 2008 11:06 am
You may also have some bad steering head bearings. To check these, raise the front end off the ground by setting some jack stands under the front section of the frame. This will leave the front end completely free for inspection. You then can grab the forks near the axle and move them front-to-back. If there is excess wear, you may be able to get away with just tightening the bearings, but chances are, the bearings are bad and need replacing.
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
PostPosted: Mon Apr 07, 2008 11:16 am
the simplest reason could be a loss of airpressure in the front tire.
PostPosted: Mon Apr 07, 2008 7:45 pm
PostPosted: Thu Apr 10, 2008 4:39 pm
MORE INFORMATION-
I took the Paso out yesterday to see what was going on. First I rode it as is. The result was that I learned the head shake occured while throttle off. Did not occur while accellerating! I thought that valuable information to work with.
I figured suspension set up might play a part in that since the headshake seemed to occur in nose down or neutral situations but not in nose up situations (acccellerating).
I increased teh front fork rebound a couple of clicks and took her back out but noticed no difference. Then I looked at the rear:
The rear suspension was set up with maximum preload and the pneumatic reservoir was set at "0". I set the reservoir to "5" to see if there would be any change.
The result was that the head shake became much worse- and occured on accelleration too.
Does that hint at anything?
SMS
PostPosted: Fri Apr 11, 2008 5:39 am
I still think that suspension aren't so important in your trouble.
A softer mono response will just increase (as it's happening to you!) the front shaking and the neutral run shows you it's not a matter of engine.
The beginning at60 kp/h make me think to an unbalanced wheel. Was it standin fro a long time before the shaking?
