ducatipaso.org • View topic - Rotor Rattle, Oh dear!
It is currently Sat Apr 25, 2026 7:29 pm
 Post subject: Rotor Rattle, Oh dear!
PostPosted: Thu Apr 10, 2008 8:47 am
907 ,320 mm front disc rotors, What a wicked bit of gear these things are, looks like at least 5mm to 10mm play side to side and 1mm to 2mm up/ down. I thought innocent bystanders were looking at my motorbike with an appreciation of awe but it was horror at the noise of the rattling "Free Floating" (into space) discs. Looks like more fun at the bank again. A mate has a 900 ss 95 model same discs and they are tight, are mine a lemon pair? or are they meant to freak everyone out?...Marty
 Post subject: Re: Rotor Rattle, Oh dear!
PostPosted: Thu Apr 10, 2008 10:15 am
PostPosted: Thu Apr 10, 2008 12:48 pm
Thanks Gert ,how would you do this? ,can the discs be taken off the centres with tools or are they riveted or similar. I had a look but could not work it out, Thanks Marty
PostPosted: Thu Apr 10, 2008 4:05 pm
You do have floating discs?
If so, rivets can be removed & shims could be switched.
Quite expensive, like 4-5 Eu/shim.
I did this myself, not complicated, no special tools.
Just a locking washer f shims IIRC.
PostPosted: Thu Apr 10, 2008 11:25 pm
Thanks Again, Gert. Regards Marty
PostPosted: Fri Apr 11, 2008 12:30 am
No problemo & good luck w this task. :thumbup:
Btw, it`s worth doing, if you doubt it...
Users browsing this forum: Google [Bot] and 12 guests
