ducatipaso.org • View topic - Disc, Rotors
It is currently Fri Jun 19, 2026 3:20 am
 Post subject: Disc, Rotors
PostPosted: Sat Apr 19, 2008 1:00 am
Now that I have the rear end in order with chain, sprockets and wheel bearings it seems I need new front rotors. :-( I have .005 to 008 run out on both rotors and they are too thin to turn or grind. Are there any after market rotors? I found a right hand side (?)( I would assume left and right are the same) on Bike Bandit but they are over $200 a side. Ouch. Any cheaper alternatives?
 Post subject: Re: Disc, Rotors
PostPosted: Sat Apr 19, 2008 7:32 am
You had a look to main brake manifacturers?
You might be lucky!
In Italy there's one that produces semi-floating rotors, but I can't remember its name :roll: You should search in elder topics, but they were about 145€ each, add shipping and change... :smoke:
PostPosted: Sun Apr 20, 2008 6:34 am
I am looking for rotors for my bike as well , after some input from others on this site I have searched and found several places selling EBC rotors for about 185 each these are the semi floating rotors so they are a better design than the originals. find a dealer that sells EBC brake parts and look for a MD630LS and MD630RS ( left and right rotors) so far this is the only thing I have found. I havent checked with ducati yet although Im sure they are expensive and they wont be floaters. good luck
PostPosted: Sun Apr 20, 2008 11:29 pm
Thanks for the numbers.
PostPosted: Mon Apr 21, 2008 12:43 am
PostPosted: Fri Apr 25, 2008 5:56 am
Yessss!
Discacciati, and ....
What Can I see in the net?
Somebody says that braking "wave" discs can fit in paso's rim!!!! :!: :!:
You know what will I do by now???
:phone: :phone: :phone: :phone:
PostPosted: Fri Apr 25, 2008 7:03 pm
Users browsing this forum: No registered users and 28 guests
