It is currently Sat Mar 28, 2026 1:19 am
| Author |
Desmo_Demon
Post subject: Re: Dellorto fine tuning Posted: Mon Apr 21, 2008 9:48 pm |
| paso grand pooh-bah |
Joined: Fri Jul 21, 2006 12:00 am Posts: 869 Location: Easley, SC
I'm running the Dellortos with K&N filter pods. Is there supposed to be a lot of intake noise with this setup?....I can heard the air being "gulped" into the carbs as the bike idles, and it's fairly loud.
_________________ 2002 Ducati 748 monoposto 1998 Ducati ST2 1996 Suzuki GSXR-1100 1994 Bimota DB2 1988 MegaPaso 916 project 1987 Ducati Paso 750 1985 Harley FXEF 2001 Ducati M900ie (wife's) 2000 Yamaha YZF-R1 (wife's) 1998 Ducati ST2 (wife's) 1994 Suzuki GSX-750R (wife's)
| Top |
Skins
Post subject: Re: Dellorto fine tuning Posted: Mon Apr 21, 2008 10:20 pm |
Joined: Tue Oct 26, 2004 12:00 am Posts: 1304 Location: Kapiti, New Zealand
My only experience is with Malossi equipment. I keep my filter sponges well oiled, and the intake noise when idling is hardly noticeable. I can sure hear the suction under acceleration, however.
Another thing to check with Del Ortos is that the choke piston system is sealing well, with plenty of slack in the choke cable, so that it's not influencing the mixture when not required.
Also, I have heard that Ducatis with two-into-one exhausts are not so easy to tune, although I can't see why that should be so different to the Paso's two-into-one-into two system. I have a mate with a late model tuned 750 Sport (fuel intected) with a two-into-one system which makes heaps of power and runs well.
| Top |
Desmo_Demon
Post subject: Re: Dellorto fine tuning Posted: Thu May 08, 2008 11:50 am |
| Top |
jcslocum
Post subject: Re: Dellorto fine tuning Posted: Sun May 11, 2008 11:31 am |
These carbs are finicky! I found that the intake had a lot of sweet sounding HONK when on the throttle. I had the same set up with the K&N's. I liked the sound.
| Top |
Users browsing this forum: No registered users and 10 guests |
