ducatipaso.org • View topic - oil temps??? too cold or just the indication
It is currently Sun Feb 08, 2026 5:43 am
 Post subject: oil temps??? too cold or just the indication
PostPosted: Sat May 10, 2008 8:10 pm
I heard somewhere that these bikes run pretty cool. my temp guage only shows about 150F after a good ride. that seems to cold for proper moisture evaporation. does sound normal to other riders??? I havent checked my indication system for accuracy yet. if they do run this cool does anyone block of an oil cooler to get temps up??? John
 Post subject: Re: oil temps??? too cold or just the indication
PostPosted: Sun May 11, 2008 2:34 am
That sounds right. Mine gets to 65C (150F) during "normal" riding, only getting any higher if trapped behind traffic on a tight hilly road and you are using 2nd & 3rd gear for some time. As soon as you are passed the traffic it is back down to 65C.
Fraser.
PostPosted: Mon May 12, 2008 2:16 am
I think the accuracy of the guage or sender is crap. PLUS we know the wiring is crap and if I take a look at the diagram I'm sure I'll find that the wire goes to the tail light before it gets to the gauge ;-P
PostPosted: Mon May 12, 2008 5:16 pm
Hole 750 electirics is crap.... :lol: ..too small wires.. too less relays... too many bad connectors... and also brakes are crap... ;)
PostPosted: Mon May 12, 2008 7:36 pm
Does it mean the whole Paso 750 was a crap??????????????
PostPosted: Mon May 12, 2008 8:11 pm
Come on guys, it's not that bad! I've seen my temperature gauge show a range of readings in different riding conditions - like Fraser - and I'd say it's reasonably accurate. Several times, when I was tuning my carbs for idle and slow running, I'd run the bike to get to the temperature I was wanting to test at, and I felt confident. The bike runs at similar temperatures in similar condiitons to other makes I have ridden, especially Honda VFR and Honda VTR, however I would agree that mostly it runs cooler - which I like. It keeps things on the safe side, with less wear.
PostPosted: Tue May 13, 2008 2:55 am
actually too cool isnt the best thing either, maybe they were designed for it but at the very least they will have trouble boiling moisture out of the engines after sitting or when moisture condenses from hot cool cycles. but if they are all running at these lower temps and are not haveing problems then who am I to argue with success. I guess nothing is published as to acceptable temps so they are what they are???? if its bad at least I'm not alone John
PostPosted: Tue May 13, 2008 4:36 am
If the engine is running too cold, then easy to put some plastic (like cut from old oil can) between oir radiators and fairings, that air is not going thru oil radiators. That function well in my bike and here in north need to take another plate away only hottest time of summer and if drive only in towns/cities....
Frankie: Hole 750 Paso is not crap, only some things there. Its one of prettiest motorbikes ever made... :thumbup:
PostPosted: Tue May 13, 2008 7:28 pm
PostPosted: Thu Jun 05, 2008 10:25 am
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
Users browsing this forum: Bing [Bot] and 13 guests
