It is currently Sat Feb 07, 2026 6:42 pm
[ 7 posts ] |
| Author |
Post subject: general question about floating discs Posted: Wed May 14, 2008 6:50 pm |
| paso grand pooh-bah |
when do I know if I have to replace the floaters ?
| Top |
Post subject: Re: general question about floating discs Posted: Thu May 15, 2008 7:24 am |
I mean the floaters that connect the outer brake disc with the center piece. Are they only changed when the disc needs to be changed ? Isn`t it that the floaters could have too much play ?
| Top |
Finnpaso
Post subject: Re: general question about floating discs Posted: Thu May 15, 2008 6:04 pm |
Joined: Mon Jul 26, 2004 12:00 am Posts: 3081 Location: Finland
There are "semi floaters" and "fully floaters". 907 have semi floaters and then rivets are quite tight, but in fully floaters rivets are so "loose", that friction part can move very easily sideways, when brake pads touch discs....
_________________ Antti http://www.youtube.com/watch?v=HeKOh3XoXPg&NR=1 KTM 990 Adventure -08 metal dark grey Paso 750 -89 red/metal grey Paso 907IE -91 red/metal grey Paso 907IE -91 red 2xST4S -02 red/metal grey ST2 -01 red/metal grey Volvo V70 Bi-Fuel Classic/titanium
| Top |
jcslocum
Post subject: Re: general question about floating discs Posted: Fri May 16, 2008 1:55 am |
I would replace them with the disc replacement. Seems to me that they will wear out.
| Top |
Post subject: Re: general question about floating discs Posted: Sat May 17, 2008 10:53 am |
according to the info I have found the outer ring should move sideways but is not allowed to move front or back. If that is the case the floaters need replacement. My discs are about new,
| Top |
Post subject: Re: general question about floating discs Posted: Sat May 24, 2008 10:58 pm |
When the rotors are disturbingly rattly soundwise, change. When I had +0,8mm freeplay, sound was annoying although function was quite OK. Changed floaters to 0,4mm freeplay, all OK, function also. Freeplay rotation forward direction not a big problem, they do move a little.
_________________ Gert
907 I.E. -91 M900 -97 MTS 1100s -07
| Top |
[ 7 posts ] |
Users browsing this forum: No registered users and 21 guests |
