It is currently Fri Dec 05, 2025 2:39 pm
[ 7 posts ] |
| Author |
cat980
Post subject: clutch slave seal fitment ? Posted: Tue May 20, 2008 7:39 pm |
| Top |
Post subject: Re: clutch slave seal fitment ? Posted: Wed May 21, 2008 9:42 am |
| paso grand pooh-bah |
As the Paso and Sport have an O-ring it could be that the piston has a round shaped groove. (don`t remember) I`m using a clutch piston of a 900SS/749/996B/900M and this one has a V-type seal and a square groove. Better check if you remove your piston. I don`t think it`s ideal to put a seal that`s made for a square groove in a round shaped groove, if that is the case. However, it was done before. Check the FAQs.
G
| Top |
cat980
Post subject: Re: clutch slave seal fitment ? Posted: Wed May 21, 2008 5:48 pm |
| Top |
cat980
Post subject: Re: clutch slave seal fitment ? Posted: Wed May 21, 2008 6:02 pm |
have just stripped it out and have the following.
| Top |
Post subject: Re: clutch slave seal fitment ? Posted: Thu May 22, 2008 8:48 am |
looks good. If the outer diameter is 26mm the Xring of these models should fit
| Top |
cat980
Post subject: Re: clutch slave seal fitment ? Posted: Thu May 22, 2008 4:40 pm |
nice one,thanks m8.
| Top |
cat980
Post subject: Re: clutch slave seal fitment ? Posted: Thu May 29, 2008 9:09 pm |
| Top |
[ 7 posts ] |
Users browsing this forum: No registered users and 41 guests |
