ducatipaso.org • View topic - clutch slave seal fitment ?
It is currently Sat Feb 07, 2026 11:04 pm
 Post subject: clutch slave seal fitment ?
PostPosted: Tue May 20, 2008 7:39 pm
hi would this fit my 88 750 sport / paso?
http://motographix.co.uk/html/other_stuff.html
cheers.
 Post subject: Re: clutch slave seal fitment ?
PostPosted: Wed May 21, 2008 9:42 am
As the Paso and Sport have an O-ring it could be that the piston has a round shaped groove. (don`t remember)
I`m using a clutch piston of a 900SS/749/996B/900M and this one has a V-type seal and a square groove.
Better check if you remove your piston. I don`t think it`s ideal to put a seal that`s made for a square groove in a round shaped groove, if that is the case.
However, it was done before. Check the FAQs.
G
PostPosted: Wed May 21, 2008 5:48 pm
ideal,many thx paso
PostPosted: Wed May 21, 2008 6:02 pm
have just stripped it out and have the following.
PostPosted: Thu May 22, 2008 8:48 am
looks good. If the outer diameter is 26mm the Xring of these models should fit
PostPosted: Thu May 22, 2008 4:40 pm
nice one,thanks m8. :thumbup:
PostPosted: Thu May 29, 2008 9:09 pm
just an update from that link in my original post.it fits my piston and works a treat on my 750 sport...phew.
http://cgi.ebay.co.uk/Ducati-Clutch-Sla ... m153.l1262
