ducatipaso.org • View topic - front wheel spacer issue
It is currently Sun Jul 12, 2026 5:27 pm
 Post subject: front wheel spacer issue
PostPosted: Wed May 21, 2008 6:20 pm
as I wrote in another thread I have a problem assembling the front end of my bike.
According to the parts catalogue there are 2 spacers at the front wheel. One on the right side and one at the speedometer drive.
What outer diameter and exact width are these ?
If anyone has the front wheel removed, could you check ?
thx,
 Post subject: Re: front wheel spacer issue
PostPosted: Thu May 22, 2008 1:36 am
Here are the measurements I got with a metric ruler...
17.5mm ID x 26mm OD x 2mm
with a micrometer, I got this...
0.678" ID x 1.012" OD x 0.077" thickness
Both of my bikes only have one spacer on the right side. Neither has one on the speedo side.
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
PostPosted: Thu May 22, 2008 8:52 am
thanks very much. Strange that the manual shows one per side.
I saw an old 851 yesterday and that one had a spacer per side also.
I still wonder why there is a spacer on the right side as they only had to make the axle some milimeters longer. Only guess I have is that the threaded part shouldn`t stick out on the left fork side.
PostPosted: Thu May 22, 2008 5:32 pm
Terry,
did you actually remove the axle to check ? Just wondering if the "spacer" on the speedometer drive side could be a shim which is hard to see with the wheel still in place.
PostPosted: Fri May 23, 2008 10:02 am
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
