It is currently Thu May 14, 2026 10:33 am
[ 5 posts ] |
| Author |
Post subject: front wheel spacer issue Posted: Wed May 21, 2008 6:20 pm |
| paso grand pooh-bah |
as I wrote in another thread I have a problem assembling the front end of my bike. According to the parts catalogue there are 2 spacers at the front wheel. One on the right side and one at the speedometer drive. What outer diameter and exact width are these ? If anyone has the front wheel removed, could you check ?
thx,
| Top |
Desmo_Demon
Post subject: Re: front wheel spacer issue Posted: Thu May 22, 2008 1:36 am |
Joined: Fri Jul 21, 2006 12:00 am Posts: 869 Location: Easley, SC
Here are the measurements I got with a metric ruler...
17.5mm ID x 26mm OD x 2mm
with a micrometer, I got this...
0.678" ID x 1.012" OD x 0.077" thickness
Both of my bikes only have one spacer on the right side. Neither has one on the speedo side.
_________________ 2002 Ducati 748 monoposto 1998 Ducati ST2 1996 Suzuki GSXR-1100 1994 Bimota DB2 1988 MegaPaso 916 project 1987 Ducati Paso 750 1985 Harley FXEF 2001 Ducati M900ie (wife's) 2000 Yamaha YZF-R1 (wife's) 1998 Ducati ST2 (wife's) 1994 Suzuki GSX-750R (wife's)
| Top |
Post subject: Re: front wheel spacer issue Posted: Thu May 22, 2008 8:52 am |
thanks very much. Strange that the manual shows one per side. I saw an old 851 yesterday and that one had a spacer per side also. I still wonder why there is a spacer on the right side as they only had to make the axle some milimeters longer. Only guess I have is that the threaded part shouldn`t stick out on the left fork side.
| Top |
Post subject: Re: front wheel spacer issue Posted: Thu May 22, 2008 5:32 pm |
Terry, did you actually remove the axle to check ? Just wondering if the "spacer" on the speedometer drive side could be a shim which is hard to see with the wheel still in place.
| Top |
Desmo_Demon
Post subject: Re: front wheel spacer issue Posted: Fri May 23, 2008 10:02 am |
| Top |
[ 5 posts ] |
Users browsing this forum: No registered users and 22 guests |
