It is currently Sat Feb 07, 2026 9:36 pm
 Post subject: Valve adjust / Check on an early Paso
PostPosted: Sun May 25, 2008 5:47 am
Does anyone know where I can find a good description of how to adjust valves on the early Paso 750 that does not have the removable clips on the rocker arm shafts? I was told the pasos with the yellow rocker-box caps have the clips and earlier "plain capped" Pasos don't
Are clips easy to retrofit?
Roger.
 Post subject: Re: Valve adjust / Check on an early Paso
PostPosted: Mon May 26, 2008 8:41 am
Roger,
Here you go http://www.ducatisuite.com/valves.html
A nice step by step description.
Fraser.
PostPosted: Mon May 26, 2008 8:47 am
have you checked the workshop manual ?
I had the rocker arms on my Paso changed to the newer type with clips. I got some used rocker arms from a Supersport. The job was done by my dealer but I don`t think it`s so difficult to change them (just be sure that te valve doesn`t drop in when you remove the rocker arm).
PostPosted: Tue May 27, 2008 5:00 am
I'm pleased to hear it's possible to retrofit rocker arms with clips. When you say yours were from an SS, can you be more specific??
Roger.
PostPosted: Tue May 27, 2008 7:29 am
Roger, it has been a long time ago.
The parts came from a 750 Supersport (I guess 91-97).
I wouldn`t wonder if the rocker arms were the same on all 2 valve Ducs, at least all 750s (after 1990/91).
The rocker arm axles don`t need to be changed.
