ducatipaso.org • View topic - Aftermarket pipes??
It is currently Mon Sep 29, 2025 10:12 am
Post new topic Reply to topic  [ 20 posts ]  Go to page Previous  1, 2
 Post subject: Re: Aftermarket pipes??
PostPosted: Thu May 29, 2008 11:15 pm
Donaldo,
Those pipes look great on the 907;
Can you give us any more details on how you constructed them, materials used and what modification you needed to make them fit (other than the rear pegs)
Thanks,
PostPosted: Fri May 30, 2008 1:08 pm
PostPosted: Thu Jun 05, 2008 4:10 pm
O.K. guys I am traveling right now and will do a more detailed account with exhaust pics, materials used and measurements when I get back home. Meanwhile here is pic of the rear:)
PostPosted: Thu Jun 05, 2008 6:12 pm
:thumbup: :thumbup: :thumbup: :thumbup: :thumbup: :thumbup:
PostPosted: Thu Jun 05, 2008 10:48 pm
Hey Donaldo,
Those pipes do look great, and in fact the whole machine is very nice, very well done.
Others considering alternative pipes might try to get hold of a Limited system (eBay?). They appear stock but have a significantly larger outlet diameter. I put one on mine almost from new and have been very much pleased all these years.
http://images2b.snapfish.com/232323232% ... 4933vq0mrj
I needed to rejet and fit a low-restriction air cleaner. I believe the header pipes are larger also, as the exhaust valves were bigger than the standard 750. Not sure if they'll work on a 906/907ie though.
Make it a good day,
Sheldon
'88 Paso
'62 200 GT
'78 Laverda 3CL Jarama
'84 Laverda RGS 1000
