ducatipaso.org • View topic - Anyone Have Their Paso's Engine Removed?
It is currently Sat Dec 06, 2025 5:09 am
 Post subject: Anyone Have Their Paso's Engine Removed?
PostPosted: Sat Jun 21, 2008 10:39 pm
I think Gerhard stated that he has his engine out of his bike, but just in case he doesn't...
I need the measurements of the Pantah engine at the lower mounting points of the engine. They are very difficult to get an accurate measurement with the engine in the bike. Here are the two points I need....
It looks like there is a spacer on the right side (brake side), but if I can get the measurements of each side from the joining point of the engine cases, I can determine how wide the spacer needs to be later.
Thanks!
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
 Post subject: Re: Anyone Have Their Paso's Engine Removed?
PostPosted: Sun Jun 22, 2008 7:32 am
You can ask to lcerani as he switched a SS900 engine in the paso frame, so he had to machine all the "difference"s between newer and older carters!
PostPosted: Sun Jun 22, 2008 10:21 am
Hi Terry,
it`s already a few months now that my engine is back in the frame, Pitty, I could have measured before.
PostPosted: Sun Jun 22, 2008 3:06 pm
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
PostPosted: Sun Jun 22, 2008 6:42 pm
I have an engine out of frame but need a new battery for my calipers!!! Can you wait until next weekend?? I travel again this week for work....
PostPosted: Sun Jun 22, 2008 8:42 pm
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
PostPosted: Mon Jun 23, 2008 2:29 pm
I'm getting closer to being able to install this engine. I tried to fit it into the frame, last night, and I'm still a fraction of an inch off on those bottom two mounting tabs. The Pantah engine has a spacer on the rearmost two mounting points, and I'm trying to let the engine cases stay wide enough to not need spacers, but this is makign it very difficult to try to install. I'm going to do some more trimming and shaping, and if I can't make it go in easier, I may have to trim more on the right sides of the cases and use spacers to make installation a bit easier.....I'm getting closer. I'm hoping this works.
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
PostPosted: Tue Jun 24, 2008 4:34 am
PostPosted: Wed Jun 25, 2008 10:00 am
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
PostPosted: Thu Jun 26, 2008 11:04 am
Well, I now understand why engine swaps are not common occurances with the Paso bikes. I'm still working on this engine installation, but it is not as easy as I was hoping.....but still not as difficult as it could be. Here's an update to the Mega Paso Project. I'll add this link to the Mega Paso thread, also.
http://www.desmodemon.com/mega_paso/engine.html
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
