ducatipaso.org • View topic - Starter motor brush plate and brushes
It is currently Sun Jun 21, 2026 11:55 am
 Post subject: Starter motor brush plate and brushes
PostPosted: Sun Jun 29, 2008 4:21 pm
I replaced the starter motor brush plate and pillar with brush for my 750 Paso with identical and available Kawasaki parts.
Kawasaki ZX750 (1996-2003) and ZX900 (1994-1997) use the same parts. Two parts numbers are required:
Brush plate with one brush attached: 14079-2055
Pillar with one brush attached: 21169-1058
 Post subject: Re: Starter motor brush plate and brushes
PostPosted: Mon Jun 30, 2008 12:05 am
Good tip, thx f sharing! :)
PostPosted: Tue Jul 01, 2008 1:54 pm
Good tip, anyhow brushes are still available in duc dealers :thumbup:
PostPosted: Tue Jul 01, 2008 8:23 pm
I needed new brushes for my 900ss (1997) and baulked at paying nz$80 for the parts so I went to the local auto sparky and got a pack of 4 brushes for 12 bucks . Each brush needed a swipe with a file to fit and a small soldering job to fit to the brush plate. Most auto sparkies can also supply a suitable regulator / rectifyer at a good price . I hate to state the bleedin obvious but it is important to make sure that the starter motor is waterproofed upon re assembly
PostPosted: Wed Jul 02, 2008 5:09 pm
This is great info! Thanks!
1992 907ie Beauty. Custom high pipes, Pro Italia chip, Barnett performance clutch, Corbin Seat, Stainless brake lines. 35,000 miles. Owned since 1993.
PostPosted: Sat Jul 05, 2008 11:28 pm
Great tip, let's keep them coming! We all know that the parts for our Paso's are becoming more and more rare.
PostPosted: Sun Jul 06, 2008 2:07 am
i replaced my starter motor from a 96 ss the starter motor i believe is the same even up to the ST2 and ST4 models.
PostPosted: Tue Jul 08, 2008 10:30 am
i'd put that in the FAQ.
PostPosted: Wed Jul 09, 2008 7:17 am
Hi all.
just checked my ST2 2002 and starter motor has same part no.128000-6050
PostPosted: Fri Aug 08, 2008 9:34 pm
Is the round graphite bush that supports the armature available too???
PostPosted: Sat Aug 09, 2008 7:07 am
you would have to check with your local dealer but if the brush plate is available you would assume the bush would be too.
PostPosted: Sat Aug 09, 2008 7:13 am
already checked, brushes are not available here in the UK..I have replaced the starter with a 748 one, same part number, just would like to repair the old one as a spare....
PostPosted: Sat Aug 09, 2008 8:00 am
look up "GOWANLOCH" they are in Sydney Australia. They have a lot of little odds and sods , they may have one.
PostPosted: Thu Jul 29, 2010 4:25 am
just to add to this list of info for starter brushes
I have just bought Honda parts that fit - turns out the starter motor used on the Paso & Sport is a Japanese one so parts fairly common.
Honda part numbers for the brushes are:
31201-HA0-004
31231-ZA1-003
I paid $NZ63.00 for both.
Clive
PostPosted: Thu Jul 29, 2010 8:48 am
12 bucks
