ducatipaso.org • View topic - hello there
It is currently Sun Nov 01, 2026 4:39 pm
Post new topic Reply to topic  [ 32 posts ]  Go to page 1, 2, 3  Next
 Post subject: hello there
PostPosted: Mon Jul 21, 2008 10:43 am
hello Paso owners! :)
I have bought mine about 3weeks ago, year 1990.
there is a lot work to do as a previous owner didn`t look after this lovely bike but anyway
it`s great to have it now :)
recently I have changed oil & oil filter, please take a look at this picture, as I suspect
that there is something wrong with oil controll.
it seems that my "control oil level" is "blind", its all white, and I cant see oil level.
what can be wrong?
regards!
greg
 Post subject: Re: hello there
PostPosted: Mon Jul 21, 2008 1:42 pm
Hi.
I will guess that it is moist inside the engine that will dry out if you take the bike for a long trip to heat it up to normal working temperature.
Håvard
PostPosted: Mon Jul 21, 2008 3:29 pm
As you know H20 is a by product of combustion motor. If a motor sits for long period of time in storage water will accumulate. After you ride it for a long ride or a few it should clear. :thumbup:
1992 907ie Beauty. Custom high pipes, Pro Italia chip, Barnett performance clutch, Corbin Seat, Stainless brake lines. 35,000 miles. Owned since 1993.
PostPosted: Mon Jul 21, 2008 8:45 pm
Was it this color when you bought it 3 weeks ago or has it suddenly clouded up and turned white??
PostPosted: Mon Jul 21, 2008 8:55 pm
hello guys,
thanks, it`seems that you are right as from 1997 the bike did only 4000 miles :)
(according to MOT)
jcslocum: the color was the same!
I`ve got another problem, after leaving bike on "neutral" gear, when I come back
after 2-3 hours, gear seems to be blocked.
I do can change to "first" gear, but then I cannot use "neutral" or "second" gear and so on...
I have to ride about 5-10 minutes, so the gear is unblocked.
what can be the reason?
btw: whats the oil capacity? as I was not able to check the level when changing the oil.
I put aprox. 2.5litres, and then after running the engine for about 5minutes, I put another 0.7
regards!
PostPosted: Tue Jul 22, 2008 12:21 pm
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
PostPosted: Tue Jul 22, 2008 4:55 pm
PostPosted: Tue Jul 22, 2008 6:05 pm
Desmo_Demon, when the engine is cold, I can get the bike into the 1th gear ONLY! (from neutral gear)
then, after riding 5-7 minutes i can get into 2th and so on..
paso750, the problem is that it`s not possible to see the oil level through the window :)
btw, guys, I know you are experts about Paso :) is it possible that you could estimate the engine condition
by listening it when it`s running? :)
PostPosted: Tue Jul 22, 2008 6:15 pm
PostPosted: Wed Jul 23, 2008 5:46 am
The plastic "glass" in the window can happen to loose completely its propriety and become "milky". There's a manifacturer that sells in ebay an handmade spare cap.
If the gear runs well after some minute, this means that it needs warm temperature to do:
How long did the bike stand by before you bought it? this might be a temporary problem that will go with a short rodage :)
Anyway, take attention to it!
PostPosted: Wed Jul 23, 2008 4:58 pm
If there is a lot of condensation in the oil (white deposit on sight glass) then the piston rings might be worn. I use 3.5 litres of 15W40 oil for my Paso and its a good all round performer.
PostPosted: Fri Jul 25, 2008 1:15 pm
PostPosted: Fri Jul 25, 2008 2:47 pm
hello guys,
thanks for you help, but I`ve got another problem ;)
hope you could give me any advice that could help...
I get Paso about 3weeks ago but as I had to register it in my country
it had to stay at parking (we have bad wether, its raining all the time
so maybe thats the problem? ;)
so I ride Paso only a little bit, and there was no problem, except the gear
(that i described above)
but then I changed the oil, and one problem appeared, when I hold the clutch,
and push the bike (with engine off) - the bike is scratching.
when I turn on the engine, the gear is on neutral, the engine sounds very nice,
but when I hold the clutch (preparing to get into 1th gear) the engine makes very
bad sound...
then, when I get into 1th gear and start riding, the sound disappear.
but when I try to hold the clutch again - the sound come back :)
what can be the problem? oil that I put was motul 10w40.
but as I said maybe sth corroded because of the rain?
I`m very close to regret that as for my first bike I bought so old model ;)
but I couldnt resist when I saw Paso :) and I had to buy it :)
regards!
PostPosted: Fri Jul 25, 2008 7:02 pm
If Its only that "rattle and hum" from DRY clutch, its 100% nomal for all Ducatis..... :mrgreen: :mrgreen: :mrgreen: But if its something very strange and awfull noise, then its time to open clutch(very easy operation) and check bearings and all plates. If U open dry clutch, keep on eye, what was the order of plates that U can rebuild it again with same order..... Min thickness U can find from workshop manual.
Anyway seems, that U are first Paso owner from "eastern Europe" ??? :thumbup:
Btw, 15W-50 fits better to Ducatis..... Shell Ultra Advance 4 fully synthetic. :smoke:
PostPosted: Thu Jul 31, 2008 9:48 am
as far as I know there`s one guy in my city with Paso 750 (painted with white&red)
anyway, I ride a little bit and the problem witch clutch disappear :)
