It is currently Mon Apr 27, 2026 2:12 pm
 Post subject: sprocket/chain and clutch line question
PostPosted: Thu Jul 31, 2008 11:44 am
i am planning to add a 42t rear sprocket and replace my chain. will i have to add a 110 link chain or will the stock 108 links work?
does anyone still make a stainless steel clutch line for a 1993 907ie?
thanks in advance
bill
93 907ie
72 norton commando
71 triumph t100c
66 norton 650ss
 Post subject: Re: sprocket/chain and clutch line question
PostPosted: Thu Jul 31, 2008 1:13 pm
GALFER makes them. You find them on ebay.
But you can also take any other if the length and the angle of the fittings is correct. The line I`m using came from a big scooter.
PostPosted: Thu Jul 31, 2008 6:12 pm
Not Sure about your chain issue; but paso750 is correct Galfer model "FK003D94CL" is made for the 907IE Clutchline, just replaced mine this spring.
PostPosted: Sat Aug 02, 2008 12:38 pm
thanks to all who replied!
did a google search and came up with a vendor. i went for both the brake and clutch lines/ i'll have to see if i need a longer chain when the sprocket arrives.
bill
