ducatipaso.org • View topic - Nervous Engine below 2500 rmp
It is currently Fri Nov 14, 2025 8:14 am
 Post subject: Nervous Engine below 2500 rmp
PostPosted: Sat Jul 19, 2008 4:18 pm
Hi there,
Riding a 906 for a couple of weeks now and I do have a (minor?) problem with it.
When riding under the 2500 rmp and when I want to accelerate the engine holds in and starts to backfire a little bit. When opening throttle very, very slowly, there's no problem.
It's also a bit non responsive on the throttle after closing it and opening again at higher speeds.
When opening more than 1/2 there's now problem at all. Goes like a lunatic!
Does it sounds familiar to someone? Is it the Weber or should I search somewhere in the electrics?
Best,
Menno
 Post subject: Re: Nervous Engine below 2500 rmp
PostPosted: Sat Jul 19, 2008 8:29 pm
Welcome Menno,
I'd say that less than 2500 rpm are very low for a carbed V twin, so that you can't pretend a smooth acceleration.
On my 906 (less on the 907), the bike used to jerk along.
No matter, it's really hard the tuning of the Weber...
PostPosted: Mon Jul 21, 2008 8:49 pm
Menno,
Sounds like the carberettor needs to be tuned and the throttles balanced. Riding the engine at this low RPM will also make the engine very "jerky" and it will shake a lot. Keep the revs above 3500 RPM all the time and it will be smoother.
PostPosted: Tue Jul 22, 2008 12:24 am
I agree with the above comments in that they are a bit poxy at low ish revs , but if you are into "fiddling" I would check the fuel flow from tank to carb ( as a matter of course ) but mostly I'd be interested to confirm that both accelerator pump nozzles are discharging. remove air box , look down throttle bores and open throttle and you should see two squirts of fuel ( one per venturi ). you dont say how old the spark plugs are , or how long since the valves were "done "
Ps the accelerator pump test should be done with the motor NOT running. Ha ha ha I just had this mental image of some guy with an eyeball hovering over each venturi ( there about the right distance apart ) tweakin the throttle coz if it decides to spit back , which it will probably do without the air box assy............. the injury ( whilst hysterically funny to any bystanders ), would not be nice , and it is difficult to explain to everyone where all your face hair went
Good luck
PostPosted: Wed Jul 23, 2008 5:52 am
Have a look to my suggestions for carb tuning in the 750 F.A.Q. post :thumbup:
PostPosted: Wed Jul 23, 2008 4:55 pm
PostPosted: Wed Jul 23, 2008 10:24 pm
Hi Guys,
Thanks for the comments so far. Think I will start with the Weber. Allthought it might take a little while because last weekend the cluch broke down. The pressure cilinder (slave) has found a way right through the pressure plate! Completely worn. Ordered some parts; new cilinder and a used pressure plate. Have to fix that first. We have to keep on riding of course.. Keep you posted.
Menno
PostPosted: Sat Aug 02, 2008 7:42 pm
Hi Menno,
Maybe you check your fuelpressure too.
I had a 900SS with weber. No fun.
it profed difficult to the card.
later I read somewhere that Ducati had "forgotten" to build in a fuel pressure regulator, which probably could have cured my problems at that time.
good luck
Ducbertus
PostPosted: Mon Aug 04, 2008 11:03 am
Start with new spark plugs and work from there. Cheap things first!
Brake late & brake hard,
jomo
Paso 906 Blue
Paso 906 Silver
Bultaco Metralla GT370 Custom
Bultaco Metralla GT250
Bultaco Frontera 250 Mk.9
Suzuki RMX250
