ducatipaso.org • View topic - Just wanted to say hi and of course a question or 2
It is currently Sat Jun 20, 2026 3:48 pm
 Post subject: Just wanted to say hi and of course a question or 2
PostPosted: Fri Aug 01, 2008 11:45 pm
New to the board and new to a 1988 blue Paso 750. Starting issues right now, not idling with choke off. I'm thoroughly cleaning the carbs, fuel line, & filter at the petcock. Should be good at that point.
It does have black Yoshimura pipes on it so I'm wondering if it either already is rejetted or needs to be. The bike has the Mikuni setup. Anyone have a 750 with yoshi's on? Jetting advice for PNW?
Sources for timing belts?
Been reading this site several days before acquiring the bike. Very nice and helpful. The FAQs are great! :mrgreen:
Looking forward to the ride after the tune. :thumbup:
 Post subject: Re: Just wanted to say hi and of course a question or 2
PostPosted: Fri Aug 01, 2008 11:50 pm
The belts are a standard automotive part, widely available.
PostPosted: Sat Aug 02, 2008 12:04 am
Just realized the hoses to the oil coolers are, um..let's say, shot. I really hope there is an alternative for that one.
PostPosted: Sat Aug 02, 2008 1:13 pm
Just pull the coolers and lines and take them to a hose shop. They can make new lines for you for about $60 and you'll be good to go.
The belts are easy to change and available for the local Duc dealer.
Poor starting or idle can be electrical with very low voltage to the coils. There's a wiring upgrade that you can do.
PostPosted: Sat Aug 02, 2008 1:35 pm
my 1001st post :)
be sure you get the right belts as some Ducatis use round and some square teeth belts. Check your belt pulleys if you`re not sure.
Regarding the jetting, you`ll find infos about the standard jetting of the 750SS in the FAQs. So you can check if the jetting is original or not.
This jetting is not the ideal for the Paso but it works. Not all aftermarket cans need rejetting of the carbs. There`re numerous on the market that don`t have any power gain, are even worse than original cans and just make more noise.
Others require rejetting or otherwise you`ll notice a high speed loss and lean stuttering at higher speeds. Both normally don`t really impact idling though. So as Jon said it`s probably electrics.
PostPosted: Sun Aug 03, 2008 12:05 am
PostPosted: Sun Aug 03, 2008 4:53 am
I'm a fairly new paso owner (88 limited) mine has mikunis on it and it didnt idle well when I got it and it wasnt happy without choke although it would eventually warm up and run OK. before I could get around to jetting and or carb issues I bought and installed a set of Cobra F1s and now it runs great, I dont even use the choke to start and now it will idle down to a proper RPM, I am in phoenix so its pretty warm here, anyway the point being it wasnt jetted right for stock pipes but was spot on for the F1s, you gotta love being a little lucky every now and then. the mikunis were off of a later 906 or 907 (whatever) and they were probably a little fat in stock form for the stock pipes on the 750, the guy I bought the bike from probably never got around to rejetting the pipes. good luck John
PostPosted: Sun Aug 03, 2008 8:58 pm
PostPosted: Tue Aug 05, 2008 1:12 pm
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
PostPosted: Tue Aug 05, 2008 2:40 pm
says the guy who already has past 50% of that being here 2 years less than me :mrgreen: :mrgreen: :mrgreen:
PostPosted: Tue Aug 05, 2008 4:49 pm
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
PostPosted: Sun Aug 10, 2008 3:39 am
The oil cooler hoses were severely cracking. Replaced them this weekend for a total of $10 in materials from a local outfit that sells hoses, rubber, and many other useful items.
Took a permanent marker and marked and numbered the positions of the hardware and hoses. Cut off the bell of metal over the ends with a dremel cut off wheel. Got the rubber off. Ran it all down to the supplier where they cut the new hose to exact length and gave me the crimp type clamps. Could have them do it all there, but I decided to save the $60-$70.
PostPosted: Sun Aug 10, 2008 11:29 pm
That's great! Nice to be able to do some things on your own and save some decent bucks.
PostPosted: Mon Aug 11, 2008 8:31 am
if you cut your original hoses can you confirm that the hoses are multilayer ?
I heard from mechanics that some cracking is totally normal and not an issue as the hoses are made of several layers of material. I`ve never seen how the hoses were made inside. Can you make a picture ?
PostPosted: Tue Aug 12, 2008 4:22 am
