ducatipaso.org • View topic - hello there
It is currently Mon Mar 02, 2026 3:22 am
Post new topic Reply to topic  [ 32 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: hello there
PostPosted: Thu Jul 31, 2008 2:28 pm
Sometimes, if bike is without driving long time, happens, that clutch plates stick together(corrosion little) and then clutch need use, or open/take all parts away and package again..... Anyway i would open it and see condition. Easy job! :thumbup:
Btw, WHERE in Poland You live ???
PostPosted: Thu Jul 31, 2008 7:52 pm
I`m a newbie if it comes to mechanics stuff ;) but I keep learning ;)
As for now I live in Cracow (south Poland) but in 3 months I`m moving into
Russia so I`ll have to leave my Paso, as taking it into this wild (but beautiful
and amazing as well) country would end changing the owner ;p
and you? maybe north-east Finnland? :)
PostPosted: Fri Aug 01, 2008 11:26 am
I drove from Bialystok, Lublin, Rehzow, to Ukraina border 25.june and when i came back 14.july, i drove via Bielsko Biela, passing Warsaw east side and then to Bialystok again... So, i was very close to You some weeks ago. :thumbup:
I live in south/east part of Finland and only 330kms to St.Petersburg...luckily Fin side of border!!!! :mrgreen: :mrgreen: :mrgreen:
PostPosted: Sat Aug 02, 2008 6:47 pm
you were in Poland with Paso? :)
anyway let me know if you are next time ;)
I asked if you live in north - east part Finnland as some time ago
I wanted to visit Murmansk and check is it true that bears walk the streets ;p
cheers!
PostPosted: Sat Aug 09, 2008 1:22 pm
This summer i was in Poland with my ST2, but i have been in Poland very many times with my Pasos also... I visit Romania/Slovakia area near every summer holiday... :thumbup:
Its quite normal, that bears walk there in the streets ..... like also pretty girls with high heels.... U know those russian women.... :lol:
PostPosted: Sun Aug 10, 2008 9:41 pm
;) havent you damaged your bike using our polish roads? ;)
coming back to my problem with milky oil window. - it hasnt changed,
I`m still not able to check oil level, moreover I have noticed twice that
there`s some oil on the ground (like it has drained)
I tightened the oil draine screw, but anyway... how can I check the oil level?
maybe I could replace oil window??
ps. Finn girls are also pretty ;)
PostPosted: Mon Aug 11, 2008 3:10 pm
I think here somewhere was good article long time ago about options for that oil window, so let someone, like G-man help You to find it from these sites. He have time to play with his computer alot.... :wink:
About girls, i think best looking are in "eastern / southern Europe" :mrgreen:
PostPosted: Mon Aug 11, 2008 4:37 pm
this ?
viewtopic.php?f=1&t=1994&hilit=oil+sight+glass
PostPosted: Mon Aug 11, 2008 6:46 pm
Just that one! :thumbup:
PostPosted: Sun Oct 05, 2008 10:34 am
I think you need to look at te water pump seal anbd shaft. nothing expensive. just a seal probably. Maybe put the bike on the centre stand after fixing tghe seal, run the motor with cheap oil to flush out the water, then refill with correct oil. If milky, either look into impeller seal problem or at least change oil again after fixing seal
You won't get milky oil unless your water pump seal leaks into your motor. FACT!
Brake late & brake hard,
jomo
Paso 906 Blue
Paso 906 Silver
Bultaco Metralla GT370 Custom
Bultaco Metralla GT250
Bultaco Frontera 250 Mk.9
Suzuki RMX250
PostPosted: Sun Oct 05, 2008 10:39 am
Is that my typing or is there a problem with the system? Sorry, it may be the beer or wine!
jomo
Paso 906 Blue
Paso 906 Silver
Suzuki RMX250
PostPosted: Sun Oct 05, 2008 11:44 am
the P750 is oil, not watercooled.
PostPosted: Sun Oct 05, 2008 1:52 pm
...and air cooleed... ;) This time Finn was more accurate, than German.... :mrgreen: But surely G is normally much more, than me... :thumbup:
PostPosted: Sun Oct 05, 2008 8:47 pm
I`ve taken off the oil glass and try to clean it, but believe me - it`s impossible
I was scratching the window from inside - with no results.
I have found one on ebay
http://cgi.ebay.co.uk/Ducati-oil-view-g ... 286.c0.m14
PostPosted: Mon Oct 06, 2008 1:14 am
Mike B.
08 HYM 1100S
06 800SS
89 KLR650
87 750 Paso LTD
64 125 Bronco
