ducatipaso.org • View topic - Cambelts - before changing
It is currently Thu Jun 18, 2026 12:37 am
 Post subject: Cambelts - before changing
PostPosted: Sun Aug 10, 2008 9:52 pm
Right, first job now the bikes home is to change cambelts. Ive some on order, waiting for the postman. Heres some pics of the condition when i took the covers off :
The centre / crank pulleys:
The horizontal belt:
The vertical belt:
The bike had been standing for quite some time before i took it home, and no idea when belts last changed, but there didnt sem to be any major concerns or damage to them. However, there is a load of crap around the vertical cam pulley - not sure if its old rubber or oiley dirt (any way it will all be cleaned away nefore the new belts go on) :
 Post subject: Re: Cambelts - before changing
PostPosted: Mon Aug 11, 2008 3:29 pm
I am QUESSING now, that someone have tighten too much those belt cover screws, then that rubber start to turn and it can hit to belt and grinding start. I noticed thiskind one time, when i turned those screws too much and then that rubber part started to turn and belt touched that rubber and started to make some noise.... I opened immdiatelly covers and find small part of rubber gone away already... As I say, this is quessing..... :thumbup:
PostPosted: Tue Aug 12, 2008 12:32 pm
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
PostPosted: Wed Aug 13, 2008 11:53 am
It can be also so, as U say.... :thumbup:
Also all pulley(and "lead rollers" bearings) must be roll easily without too much friction. I have seen many Ducatis, what have lost those bearings and then its again bad thing.....and very harmfull to belts..... :smoke:
PostPosted: Wed Aug 13, 2008 4:26 pm
This might also be the right time to make an accurate ceck to the bearings and wonder if it's bettere to upgrade to roller/bearing alike newer desmodue :thumbup:
PostPosted: Mon Aug 18, 2008 12:56 am
Changing belts, its really and easy project when you have the manual. Also go to Ducatitech.com and see the video.
PostPosted: Mon Aug 18, 2008 1:32 pm
or:
http://www.ducatisuite.com/valves.html
PostPosted: Mon Aug 18, 2008 3:30 pm
Thanks for the tips Guys. Upon closer inspection, its definitley a mixture of dirt and rubber, but i think its accumulated over quite some time.
I havent fitted the new belts yet, as the engine is coming out for a thorough clean degrease and bit of paint before checking and replacing any parts. I can see that the vertical belt has been rubbing on something (not by much), but cant see where yet - should be able to see where once its all clean.
PostPosted: Thu Oct 16, 2008 11:29 pm
wouldn't hurt to change the oil seals behind the cam pullies , probly should do the ones in the clutch too
