ducatipaso.org • View topic - Paso 750 Rear Tire 160 60 16
It is currently Wed Mar 11, 2026 11:58 am
 Post subject: Paso 750 Rear Tire 160 60 16
PostPosted: Mon Aug 18, 2008 12:47 am
In twenty years of riding I have run throw many sets of tires on my Paso 750, I just used up the last rear. I can't find a replacement. Were do you go to find a new rear tire 160 60 16? Or is there a useable alternative size?
 Post subject: Re: Paso 750 Rear Tire 160 60 16
PostPosted: Tue Aug 19, 2008 12:47 am
OK, I searched the Web and found a site that has Michelin A59X / M59X, http://www.partsforatvs.com. I placed an order for a rear.
PostPosted: Tue Aug 19, 2008 4:38 am
you should call first.... a lot of sites show that tire but they never have them in stock. Good Luck
John
PostPosted: Tue Aug 19, 2008 7:09 pm
.. at least they cant be newer, than 2004 .... ;) i think, 2004 tires start to be already quite hard ones....... :smoke:
btw, is it tire, or tyre? i have seen both to use.... Sorry, my bad english... :mrgreen: :mrgreen: :mrgreen: .. too lazy to look from dictionary! :lol: :lol: :lol:
PostPosted: Tue Aug 19, 2008 7:13 pm
If they are stored properly,cool and dry and dark wrapped in tape there is no reason to be afraid of a tire that is 2 or even more years old
PostPosted: Tue Aug 19, 2008 10:38 pm
to continue,The safety of a tire,any tire is a factor of the oil content of the compound. As the oil evaporates the rubber compound hardens and looses its ability to flex which of course produces more heat and shortens the life of the tire faster.There are many factors which lead to the evaporation of oil from a tire. Sunlight and ozone are the two biggest factors aside from heat leading to the premature aging of a tire. Generally the average consumer tire has a life expectancy of 6 years maximum. Racing tires are of course another issue altogether.
PostPosted: Wed Aug 20, 2008 10:05 am
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
PostPosted: Wed Aug 20, 2008 10:20 pm
actually in the states its pronounced donuts :shock:
PostPosted: Thu Aug 21, 2008 4:26 am
Here front is called "etunakki" and rear is called "takanakki" ... btw, "nakki" is small sausage :lol: :lol: :lol: and etu is front and taka is rear.....
PostPosted: Tue Aug 26, 2008 1:52 am
PostPosted: Fri Sep 12, 2008 4:23 am
I found a correct rear at the VMD swap meet in Ohio last July. It was new old stock (NOS) Michelin M59 and in very good condition, i.e. not dry and cracked. Got it for $60.
My problem is the front, so settled for a Pirelli 120/80x16, meaning I had to space up the fender, as others have shown on this site. It looks wrong and raises the front end; the up side is the bike is now easier to put on the center stand.
Have just detailed the whole machine, following a major service at 29K miles. You know, valve adjustment, new cam belts, fluids, plugs etc, etc. I want dearly to ride it, but am reluctant to put wear on irreplacable tires. :dunno: :?
Make it a good day,
Sheldon
'88 Paso
'62 200 GT
'78 Laverda 3CL Jarama
'84 Laverda RGS 1000
PostPosted: Fri Sep 12, 2008 12:49 pm
Perhaps, it would be wise swap to the 17" wheels, preserving the rare 16" tires...
PostPosted: Fri Sep 12, 2008 5:01 pm
I'm afraid you're right, Francesco. Looks as though I need to research how to do it. I think there are several posts on this site that explain and show how.
Since I'm not a collector, I should probably sell it...but that would mean I no longer have it. (Can't bear the thought, as I've owned it since it was new and have 30K miles of fond memories. :truck: )
Make it a good day,
Sheldon
'88 Paso
'62 200 GT
PostPosted: Sun Sep 14, 2008 9:02 am
Yes, there are several threads on the forum, so you'll find all you need to do it.
I don't think it needs to be a collector to keep a Paso.
Really, I think the Pasos will not have any good value in the future as collectors' bikes.
I use mine (even if always less), but I always love it.
