ducatipaso.org • View topic - Swing arm damage, can I weld it?
It is currently Mon Sep 29, 2025 3:02 pm
Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
 Post subject: Re: Swing arm damage, can I weld it?
PostPosted: Mon Nov 26, 2007 9:32 pm
So, have all the aluminium parts of the bike (footpegs etc.) that coating?
I have thought only that exotic parts anodized blue, gold or so...
Is it so?
So, in that way, can I have the original aluminium finishing :?: :?: :?: :?: :?: :?: :?: :?: :?: :?:
PostPosted: Mon Nov 26, 2007 10:42 pm
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
PostPosted: Tue Nov 27, 2007 5:32 am
Frankie, Your footpegs re ALSO anodized!
PostPosted: Tue Nov 27, 2007 6:06 am
In conclusion, it's possible re-anodize the aluminium parts, if I well understand.
I wonder, will it be expensive :?:
PostPosted: Tue Nov 27, 2007 3:23 pm
U understood well. And its quite expensive, but it can be done also at home, if You know exactly, what to do. I ahve seen in net some stories, how to do it, but simply need at least chemicals, suitable ectricity(DC power supply with high amps), suitable "pool", where to put stuffs... Colour U can choose whatever, they use normally those clothing colouring knobs/bullets... :twisted:
PostPosted: Tue Nov 27, 2007 6:00 pm
I never will be able to do such things.
I meant about some craftsman who could do it.
So, it's possible. Only it needs to find who can make it :mrgreen: .
PostPosted: Tue Nov 27, 2007 10:09 pm
hello,
anodizing diy is possible but there are some snares.
first you have to pickle your parts, best with soda lye ->corrosive
then you need diluted sulphuric acid and a good powersource ->very corrosive
after the bath the anodized layer will be fixated in hot water.
some alloys are not easy to anodize diy. especially alloys like dural, 7075...
I tried it... it´s not expensive :D
ved
PostPosted: Tue Nov 27, 2007 10:30 pm
What kind of power source?
Have you had good results?
PostPosted: Tue Nov 27, 2007 10:52 pm
i´ve used a battery charger
the result is ok. it ptotects from corrosion.
if you want a good finish - forget it.
PostPosted: Wed Dec 05, 2007 12:44 am
You certianly can get it welded, any sheet metal worker should be able to either mig or tig weld this ( you may have to do a bit of filing to finish the job off ).You will , of course have to remove the swing arm, sooooo I really hope the pivot bolt isn't rusted in as mine was
PostPosted: Wed Sep 10, 2008 10:54 am
Ok.....I FINALLY got my welded 907 swingarm back from my buddy who welded it for free.....it took several months because of his lack of free time to sneak it in, but also because he has been out of the motorcycling scene for nearly a year.....but I have no idea why.
Here is what my $20 eBay 907 swingarm looked like when it arrived....
This is what it looked like when it was welded...
This is what it looked like when I filed the welds...
This is what it looks like after hitting it with some 220-grit sandpaper...
It still needs some work to clean it up and I probably need to get a little more welded to make it even better, but it is coming along. Until I decide to get a couple more spots touched up, I'll have my work cut out for me while I file down the internal weld bead...
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
PostPosted: Wed Sep 10, 2008 5:12 pm
that`s the worst Paso swingarm I`ve seen so far. How can that happen ?
Nice welding btw. !
PostPosted: Wed Sep 10, 2008 6:10 pm
Propably one of those rear sprocket nuts have started to come out and that can make such damage... :smoke:
PostPosted: Wed Sep 10, 2008 10:39 pm
http://astro.neutral.org/anodise.shtml
diy anodizing,just a start
BTW media blasting will clean up most alu just fine
Users browsing this forum: No registered users and 34 guests
