ducatipaso.org • View topic - making light
It is currently Fri Jun 19, 2026 4:40 pm
 Post subject: making light
PostPosted: Fri Sep 12, 2008 4:14 pm
just would like to show what difference it can make when you clean the inner side of a headlight (using some chopsticks and a cottonball). Do not touch the chrome reflector and if at all only use very little distilled water to wet the cottonball. (don`t completely soak it).
Put your headlight on a towel, lens downwards and throw in the cottonball. Move it around with the chopsticks. If you want to turn the headlight around to see if you cleaned it all remove the cottonball before that.
beginning
while (one half done)
at the end
Actually the old beam of my Paso was even more dirty inside. A good indicator is when you can`t see the bulb inside clearly. A dusty headlight looks quite normal until you start cleaning it and see the difference ...
I recently bought a brandnew headlight for my Vespa scooter and it was the same.
 Post subject: Re: making light
PostPosted: Fri Sep 12, 2008 4:21 pm
I've done something similar with the headlight of the ST2. For it, I put some glass cleaner in the headlight housing and just swirled it around. I then flushed it out with lots of water and then dried it really well before reinstalling. The one time I used a hair drier to dry it a bit quicker and a lot more thoroughly.
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
PostPosted: Fri Sep 12, 2008 4:35 pm
Quite radical. That`s something I would not do. The reflector is usually only chrome steamed plastic and glass cleaners or other detergents that are only minimally abrasive or even create abrasive gases can attack the chrome and make it dull.
PostPosted: Fri Sep 12, 2008 5:15 pm
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
PostPosted: Fri Sep 12, 2008 8:33 pm
don`t know how good the quality of the reflectors nowadays is. I had some old fog lights once and you got a silver finger only by touching the reflector just like from cheap chrome spray paints.
PostPosted: Fri Sep 12, 2008 8:41 pm
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
PostPosted: Sat Sep 13, 2008 8:00 am
That "foggy" headlight is common problem in STs and i have opened my sisters husbands 1999 ST2 headlight and cleaaned it totally, he have been since happy with it. Its easy to open totally in ST, cause light is made from 2 pieces and its only "welded" together with some silicone, or similar stuff. I used only very sharp knife to open it from middle, then totatty cleaning and parts back again with something similar, like silicone. Very simply in ST. :smoke:
PostPosted: Thu Sep 02, 2010 8:40 am
im going in. im gonna clean with great care the internal parts of my supa dim 906 haedlight. its a european one so its got an orange filter on it for uk roads. this does not help on my preference for minor country roads! im gonna check the volts to the bulb as well. and im gonna hunt down a uk unit if anyone has a spare one :thumbup: give me a call on 07919037083 anytime. and also im going to source a yammy fz koito unit and give that a go.
1990 906 paso red and white
1991 906 paso black and gold
1997 ST2 red
1962 rover 95 p4
1997 iveco daily
PostPosted: Thu Sep 02, 2010 8:45 am
I had sent you a pm
PostPosted: Thu Sep 02, 2010 9:45 am
nice one gerhard. that is a good price too! ive bought it so now i wait for it to arrive and i can save the original unit(which i will clean) for when i visit europe! perfect and thanks again.
1997 ST2 red
1962 rover 95 p4
1997 iveco daily
PostPosted: Thu Sep 02, 2010 10:12 am
10 quid was a bargain :thumbup:
