ducatipaso.org • View topic - Weird Squeaking Noise
It is currently Mon Jun 22, 2026 11:40 am
Post new topic Reply to topic  [ 22 posts ]  Go to page 1, 2  Next
 Post subject: Weird Squeaking Noise
PostPosted: Wed Sep 10, 2008 10:39 am
I rolled 1000 miles since getting my old Paso back on the road and after the last ride this past Sunday, the bike has a strange squeak to it. It is really, REALLY loud and I can hear it over the engine. Last night I pulled the bodywork off the bike and removed the timing belt covers. The belt tension is fine and all the bearings for the tensioners appear to be ok, also.
The squeak doesn't sound like a bearing and with how loud it is, it doesn't really sound like it is coming from inside of the engine. It sounds like two peicing of metal rubbing on each other at the same harmonic frequency as the idling rpm. It sounds like it is coming from everywhere on the bike, though. I'm thinking about dropping the oil and filtering it to see if there is any metal or other parts that should not be in it. I'm also thinking about going throughout the whole bike and check the torque of all the bolts. Other than this, I have no idea.
Here is a .MOV movie file of the engine running, so you can hear the engine yourself. Any ideas?
http://www.desmodemon.com/misc_pix/paso_squeak.mov
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
 Post subject: Re: Weird Squeaking Noise
PostPosted: Wed Sep 10, 2008 10:55 am
Clutch bearing??
PostPosted: Wed Sep 10, 2008 10:59 am
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
PostPosted: Wed Sep 10, 2008 1:35 pm
Alternator cover bearing makes an awful, loud noise when it goes bad.
PostPosted: Wed Sep 10, 2008 5:29 pm
PostPosted: Thu Sep 11, 2008 10:20 am
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
PostPosted: Thu Sep 11, 2008 4:27 pm
its really easy to pull the clutch cover to check that stuff out, since its a dry clutch theres no mess either. John
PostPosted: Thu Sep 11, 2008 5:55 pm
thinking of it and what John said, remove the clutch cover and start the engine, then you`ll know instantly if it`s that bearing or not.
PostPosted: Thu Sep 11, 2008 8:55 pm
the clutch bearing worn generates a vibration on the handle lever when you pull it lightly and stops when you pull it strongly.
The alternator bearing is easy to inspect and you might find it worn and rosty!
If you need some tip for the clutch bearing, I'll give you :thumbup:
PostPosted: Fri Sep 12, 2008 5:24 am
Sounds like alternator to me too.
Good luck.
PostPosted: Fri Sep 12, 2008 5:48 am
A screwdriver handle held to the ear and the tip placed around the engine (alt cover vs clutch), should help trace the souce. Use it like a stethoscope.
PostPosted: Fri Sep 12, 2008 10:19 pm
If you remove the sparkplugs and turn the engine over by engaging a gear and turning the rear wheel you will hear this noise all the easier and hopefully where it is from.
PostPosted: Tue Sep 16, 2008 2:01 pm
I've done a few checks and have listened to several points on the engine with a screwdrive-to-the-ear method and cannot pinpoint anything obvious. I'm probably going to borrow a mechanic's stethoscope from a buddy of mine and if that doesn't help me pinpoint it, I'll probably take the Paso back off the road until I can figure out what is wrong. I don't see a point in paying for insurance if it is going to sit, and I have to do a timing belt change and valve adjustment on the Monster, ST2, and 748 in the next few months. If I had the extra money to burn, I'd take the bike to someone else to fix for me, but I don't have the extra money to spend.
With the bike sitting for at least six years, I was expecting it to give me troubles once I got it back on the road, but for some reason, this has drained away the last of my motivation when it comes to motorcycles. I haven't touched a bike in over a week (other than starting up the Paso and trying to determine what is wrong with it). I'm hoping to kick myself in the butt and start commuting tomorrow.....and I've got the Ducks Fly South rally sponsored by US Desmo in two weeks, so I'm hoping that motivates me, again.
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
PostPosted: Tue Sep 16, 2008 5:14 pm
I am wondering if this squeak can be caused by the starter sprag - if that might be another possible source. Early on my bike developed some chirping, but it was the throw out bearing.
PostPosted: Tue Sep 16, 2008 10:44 pm
