ducatipaso.org • View topic - Oil light turns on and clears itself
It is currently Sat May 02, 2026 9:39 pm
 Post subject: Oil light turns on and clears itself
PostPosted: Sat Sep 20, 2008 8:36 pm
I was wondering if anyone has had a problem with some shorts with the electronics. My bike runs perfectly, but after washing it one day and going for a ride in the afternoon the check oil light came on and then cleared itself, then took her out a few days later, 40 miles went great, then the warning light came on and cleared itself a few times.
I have the manuals, but I was wondering if anyone had some experience with this, and if it's something serious..?
 Post subject: Re: Oil light turns on and clears itself
PostPosted: Sat Sep 20, 2008 9:45 pm
Sounds like you need a new sender. Check the connection to the sender for tight and clean. Water can get in and cause problems too. Nothing too serious.
PostPosted: Sun Sep 21, 2008 3:42 pm
Those OEM units were not so good quality, so better change it and see, what happens. I have also lost one in my 750 Paso. Also those neutral light switches are poor quality... :smoke:
PostPosted: Fri Oct 03, 2008 3:08 pm
Thank you very much, unfortunately it's too cold to go out riding anymore this season here in VT, but I do have the winter left to make a new seat, fix the idiot light and do the valves.
Whitney
PostPosted: Sat Oct 04, 2008 11:55 am
- Kurt
