ducatipaso.org • View topic - parts again!
It is currently Thu May 07, 2026 6:12 pm
 Post subject: parts again!
PostPosted: Mon Sep 22, 2008 11:26 am
parts again! does any one know if the ss rear master cylinder is same as 750 paso? and also speedo cable/ desmodave
 Post subject: Re: parts again!
PostPosted: Mon Sep 22, 2008 1:46 pm
No it`s not. The mounting hole distance is 40mm instead of 50mm but maybe an adapter plate can be made ...
If I remember well the speedo cables is too short. I had 2, not sure if from Supersport or Monster and both didn`t fit.
PostPosted: Mon Sep 22, 2008 2:44 pm
ta for your quick reply g.
PostPosted: Wed Oct 01, 2008 8:59 pm
Replacement speedo cables can be ordered from . Less than £15 and very quick service.
I replaced my rear cylinder with this one but you do need to make up a plate to cater for the 40mm spaced holes.
PostPosted: Thu Oct 02, 2008 8:01 am
do you have a picture or drawing of the plate ?
PostPosted: Fri Oct 03, 2008 5:02 pm
There are 2 photos and a diagram attached. It's difficult to get an angle for a clear photo but you can get the idea.
Three holes in a plate;
bottom cylinder mounting bolt goes through lower hanger hole, hole 1 in plate and lower cylinder mounting hole
top cylinder mount is secured with countersunk bolt through hole 2 in the plate
hole 3 in the plate is used to secure top end of plate to upper mounting hole in hanger
Hope this helps
Centre 1 – Centre 2 = 40mm
Centre 1 – Centre 3 = 50mm
Hole 2 countersunk on one side
PostPosted: Fri Oct 03, 2008 6:44 pm
Great! Thiskind i like very much... :thumbup:
