ducatipaso.org • View topic - Recommended spark plugs? Oil?
It is currently Fri Apr 24, 2026 8:51 pm
 Post subject: Recommended spark plugs? Oil?
PostPosted: Tue Sep 30, 2008 10:30 pm
I'm back. Still have the 907 on the lift, tank is off now.
Spark plug recommendation? What's your preference? Champion RA6HC are currently installed. I found a chart on line that specified RA4HC.
Oil recommendation? Previous owner claims to have used Motul syn blend 15-40.
Moderate touring use expected, kind of like the way I ride my vintage Triumph. I have the Monster if I want to thrash something.
Thanks again,
- Kurt
 Post subject: Re: Recommended spark plugs? Oil?
PostPosted: Tue Sep 30, 2008 11:24 pm
Myself I wouldn't put champions in my lawn mower. NGK are fine DPR8EA9 Oil I like durablend 5-30 a low paraffin synthetic blend
PostPosted: Wed Oct 01, 2008 12:23 am
PostPosted: Wed Oct 01, 2008 11:21 am
- Kurt
PostPosted: Wed Oct 01, 2008 2:06 pm
PostPosted: Wed Oct 01, 2008 6:03 pm
sparks: NGK DPR8EA9
oil: VAlvoline 20W50 Racing, very good synthetic. As this Duc has only the big end as a plain bearing, the others like a more "thicker" olio.
Ducbertus ;)
