It is currently Mon Apr 27, 2026 7:47 pm
 Post subject: 92 instrument cover cracked
PostPosted: Tue Oct 07, 2008 3:10 pm
Was wondering if anyone knows where I can pick up a new/used instrument cover. Kid next door hit a home run onto the plastic cover and cracked it.
Gary
 Post subject: Re: 92 instrument cover cracked
PostPosted: Tue Oct 07, 2008 3:59 pm
you will have no luck finding one as they don`t exist anymore for years.
The only thing you can get is a complete instrument panel (just the same with the Euro spec rear light assembly). If you`re lucky enough to find a used one it`s probably also cracked or has the mounting latches broken off. I have a spare but with all latches broken off and needing polishing.
