It is currently Mon Dec 22, 2025 11:20 am
 Post subject: front brake light switch
PostPosted: Fri Oct 10, 2008 4:25 pm
where is this located? I have something missing near the lever two holes. what is the stop switch on the parts cat. in between the front brake hoses? is there meant to be two parts for you front brake light? .....desmodave.
 Post subject: Re: front brake light switch
PostPosted: Fri Oct 10, 2008 5:21 pm
it's mounted close to the inner triple clamp, in the 3way joint.
It's not easy to see with the bodywork installed :-(
Have a nice work, and...
PostPosted: Fri Oct 10, 2008 5:50 pm
Dave,
the brake pump is used on numerous other bikes. There may be bikes that don`t have a pressure switch and require a small switch at the pump instead. You don`t need both.
