ducatipaso.org • View topic - Rubber fairing nuts, do they fit the 907 I.E.??
It is currently Mon Sep 29, 2025 1:39 pm
 Post subject: Rubber fairing nuts, do they fit the 907 I.E.??
PostPosted: Tue Oct 21, 2008 3:06 am
Hi all...well...while finding something to buy for my bike, I found this item on ebay...the seller doesn't know if they fit the 907 I.E....what do you think?
Saludos
Nicolás
http://cgi.ebay.com/DUCATI-paso-750-906 ... .m63.l1177
 Post subject: Re: Rubber fairing nuts, do they fit the 907 I.E.??
PostPosted: Tue Oct 21, 2008 5:40 am
I have just bought the same ones from Giovannimoto - just a larger set...
if they fit the 906 and 851 they are supposed to fit the 907ie.
I can let you know when they arrive if they fit...but am confident they will be OK.
PostPosted: Tue Oct 21, 2008 8:51 am
PostPosted: Tue Oct 21, 2008 11:38 am
Normal wellnuts.... can be found from many nut/screw shops :smoke:
PostPosted: Tue Oct 21, 2008 11:50 am
Desomtimes.com sells these in the US. My Duc dealer has ordered the genuine part for me -- I think the lip is a little different. When they come in, I will report and post -- along with measurements on the missing "bullets" and grommets at the tank/panel attaching points, per other thread.
- Kurt
PostPosted: Tue Oct 21, 2008 9:17 pm
Hi Nico,
original fit the best. desmotimes seem to offer also goods ones.
I bought 50 pieces at a regelar fastener shop for € 22 to find out that the lip was over 5 mm thick instead of 1 mm.
so I grinded the lip down to 1 mm. with a belt grinder.
worked very good. :)
ducbertus
PostPosted: Wed Oct 22, 2008 5:51 pm
PostPosted: Wed Oct 22, 2008 5:55 pm
yep,
that's why I bought them NOT at the dealer.
If a nut is a little out of shape, I just put in an other. After grinding down the lip, which doesn't take a minute with a belt grinder :lol:
ducbertus
PostPosted: Wed Oct 22, 2008 6:43 pm
I have also bought such from normal nut/screw shop and they fit quite perfect... I havent made any modifications to wellnuts, or to they holes... :thumbup:
PostPosted: Thu Oct 23, 2008 12:53 am
I can also recommend the wellnuts fom Desmo times, they fit well.
PostPosted: Thu Oct 23, 2008 6:00 am
Desmoparts.com in Houston, TX, also carries fairing wellnuts. They're .70@ for M6's, and are an almost perfect replacement for factory Ducati parts, and ship quickly. The company also carries a variety of stainless buttonhead fasteners, though I personally prefer the original gloss black.
robert
'93 907ie
'75 Norton 850
robert
'93 Ducati 907ie
'75 Norton 850 Commando
'98 BMW K1200RS
'85 VW Vanagon (to haul parts for the bikes...)
PostPosted: Tue Oct 28, 2008 1:05 am
the fairing rubbers from Giovannimoto arrived and fit OK.
while "browsing" I found this MotoGuzzi site:
MG CYCLE
601 Ogden Ave
Albany WI 53502
USA
Phone: (USA) 608-862-2300
FAX: 608-862-2015
Toll Free Order: 888-464-2925 (888- 4-MGCYCLE)
EMAIL info@mgcycle.com
the web site lists various rubber components that may suit the 907;
It would be handy to get someone from the USA to check out interchangeability
tank hold down rubbers
funny under tank rubber bits to clip on side cover
side cover end bits that slide onto the rear frame spigots
6mm thread vibration mounts for ECU & regulator
