ducatipaso.org • View topic - hello
It is currently Mon Jun 22, 2026 4:31 pm
Post new topic Reply to topic  [ 22 posts ]  Go to page 1, 2  Next
 Post subject: hello
PostPosted: Tue Oct 28, 2008 10:36 pm
hello there
i'm new to this forum, riding a 87 750 Paso
I'm from the Netherlands and a bit of a ducati freak. owning a 860 bevelhead racer and a 87 750 paso. ( Also doing a bit of trackriding / racing in supermono class with a cagiva mito based supermono with a suzuki 4 stroke engine in it.)
For my work i'm in motorcycle suspension with my own very small shop
"bitubo-raceservice.nl" .as i do the raceservice in the Netherlands and Belgium for Italian suspension company "Bitubo Racesuspension".
Doing Suspension sales, services, and modification on street and racebikes
(My Paso does have the original Marzocchi M1R forks and still the Marzocchi shock (planning on changing that for a bitubo shock this winter..when i have time
My paso is mainly used for fun..riding the Belgium "Ardennes" .
Bike is not the cleanest and sometimes has had a hard life but the technical condition is fairly okay.. 70.000km on the clock and still running strong!
anyway..i like it a lot.. just because it's "different'" .
Anyway,,i used to read here sometimes..like to read about Paso's
Now i might have a change to be a part of the forum and to talk a bit.
 Post subject: Re: hello
PostPosted: Tue Oct 28, 2008 11:14 pm
Hi hakkinen,
And welcome to the forum. Talking is good, and can be help full. :)
Regards
Klaus
By the way, what tyres are you running? This is one of the big topics here :shock:
PostPosted: Tue Oct 28, 2008 11:15 pm
Welcome on the forum.
I hope you are going to be a good writer here :thumbup: :thumbup: :thumbup: :thumbup: .
PostPosted: Wed Oct 29, 2008 6:09 am
Welcome and tanks for yuor pic!
It's alwais a pleasure to see a Paso in a racing track! :thumbup:
PostPosted: Wed Oct 29, 2008 7:40 am
PostPosted: Wed Oct 29, 2008 9:00 am
Hello there,
I had a replacement Bitubo shock in the Paso once. It was the cheapest I could find and actually not bad :) It was a simple one w/o external adjuster. (are there others for the P750?).
There were 2 flaws though. At the bottom of the shock there was a small lever to adjust the shock (basically only a screw with a plastic cap on it). That was too long and needed to be shortened as it touched the swingarm linkage. The red paint of the spring also lifted off partly even though the bike was used very little.
PS: What exhaust is that ?
PostPosted: Wed Oct 29, 2008 9:14 am
PostPosted: Wed Oct 29, 2008 10:56 am
Welcome back!
What do you have for the 907 in suspension?
Rear shock, front kits/springs, prices?
PostPosted: Wed Oct 29, 2008 7:27 pm
PostPosted: Wed Oct 29, 2008 7:52 pm
Hi! I am VERY COURIOUS, from WHERE is coming that "hakkinen" ???? :)
Is that chain hitting to side of rubber ONLY problem with that rear tire??? What Mezeler it is and is it still available? i couldnt find Metzeler with such dimensions. :dunno:
PostPosted: Wed Oct 29, 2008 10:12 pm
PostPosted: Thu Oct 30, 2008 5:43 am
WELCOME! Are you using the stock rear shock? I will be adding emulators to my Pasos', I have installed them on my Yamaha Visions, and on my GSX-1100g. They do miracles!!!!
PostPosted: Thu Oct 30, 2008 10:32 am
PostPosted: Thu Oct 30, 2008 11:11 am
PostPosted: Thu Oct 30, 2008 2:10 pm
