ducatipaso.org • View topic - Timing and valves
It is currently Thu Feb 26, 2026 5:52 pm
 Post subject: Timing and valves
PostPosted: Fri Apr 29, 2005 12:02 am
Hello all.
Has any body done there own timing belt change and valve adjustments I have 12,000 on mine and just found out this has to be done, any info or advice would be great.
Theo
PostPosted: Fri Apr 29, 2005 12:38 am
The belts are a breeze to do and will take about 45 minutes to change.
The valves are on the hard side to do but if you are good with your hands. See this site for simple to follow instructions:
Good luck!
 Post subject: Timing Belt/Valves
PostPosted: Fri Apr 29, 2005 2:33 am
 Post subject: Timing/Valves
PostPosted: Fri Apr 29, 2005 2:52 pm
PostPosted: Fri Apr 29, 2005 3:18 pm
1988 Paso 750 #753965
1997 Monster 750
 Post subject: Valve Adjustment
PostPosted: Fri Apr 29, 2005 3:46 pm
PostPosted: Fri Apr 29, 2005 4:16 pm
I believe jfiore is correct - and that actually may hold true for all Pantah engines. Compared to the newer engines, which have a spring clip that essentially wedges the arm into place on its rocker, the older Pantah engines aren't quite as enlightened. Not that it's a huge deal, and if you haven't worked on a newer engine, you won't notice. But after doing this valve service, you'll notice should ever you work on a newer engine. ;)
Actually, if you're feeling saucy, I think ProItalia out in California sells a DVD detailing the valve service. A friend of mine has the older VCR tape version in which they actually take an aside and demonstrate with a Pantah head (off the bike of course, so it looks like a piece of cake).
Otherwise, first time through this whole process? If you're mechanically inclined, done carefully, I'd set aside at least three hours to get everything apart; if you're not so inclined ... much longer. ;)
In regards to the half-rings on the valves, you may consider replacing them with a collet set from ; it'll run you about $150USD and it should extend your service interval from 6k to 18k (according to them). The nice thing - you can call and speak with Martin himself; he's a great guy - very helpful and pleased to speak with anyone.
1997 Monster 750
 Post subject: Re: Timing/Valves
PostPosted: Fri Apr 29, 2005 5:09 pm
PostPosted: Fri Apr 29, 2005 6:12 pm
1997 Monster 750
 Post subject: Timing and Valves
PostPosted: Fri Apr 29, 2005 7:15 pm
You guys are ausome!
Theo :thumbup:
PostPosted: Fri Apr 29, 2005 7:31 pm
It is essential that the motor is stone cold when you do the valve adjustment. Any warmth in the components will make accurate measurement of clearances impossible.
It is recommended that the work be done after the bike has sat overnight. Even doing the work in the evening after the bike was ridden in the morning is not advisable.
Think twice about any shop that does not say you'll have to come back the next day to collect the bike.
