It is currently Fri Mar 13, 2026 1:10 am
[ 4 posts ] |
| Author |
MetalHed
Post subject: Engine bogging down Posted: Sun May 01, 2005 10:23 pm |
Okay...I'm still waiting on all of the parts to come in to switch from the weber's to mikuni's. But in the mean time, I'm having a little problem. I think it might be temperature related.
It starts great and runs fine for the first few minutes, but once I get going faster (around 65 mph) for a couple of minutes it bogs down. By that I mean moving the throttle doesn't do anything but make a noise. Even if I slow down and down shift it still just won't accept any throttle, then it dies. But then, if I just wait about 2-3 minutes it will start right back up and ride fine. I've only had a chance to ride it around a couple of times, so I haven't pin pointed exactly when it happens. There was a time when I was riding it slow through town and doing fine with temp up just past 180 or so, but once I picked up speed temp went down to the bottom of the guage (I think around 120) and it died shortly after.
Does this sound like it would make sense? Looking at it, I think the oil coolers seem way too big for the bike, maybe I should plug one of them off? What does everyone think?
I will say though, in between breakdowns this bike was a lot of fun!
| Top |
jcslocum
Post subject: Posted: Sun May 01, 2005 11:06 pm |
| paso grand pooh-bah |
I don't have the webers anymore but it sounds like it's sdtarving for fuel. Chsck the fuel filter and make sure the vent is open into the tank. If air can't get in, the fuel can't get out.
| Top |
jfiore
Post subject: Bogging Down Posted: Tue May 03, 2005 2:27 am |
Joined: Wed Jul 21, 2004 12:00 am Posts: 67 Location: Windsor, CT USA
I agree with jcslocum. When the engine bogs down, pull over and try opening the gas tank cap. If you hear a "whoosh" of air going into the tank, then your vent line is blocked.
If there doesn't seem to be any problem with vacuum build-up in the tank, then either your fuel line is clogged or your fuel pump is not working. Check for voltage at the fuel pump terminals as a first test. If the voltage is at least 10 volts DC, then disconnect the fuel line from the tank to the pump to check for fuel flow. If there is a decent flow of fuel out of the tank, then hook the line back up and disconnect the fuel line going into the carburetor to check for pump output. If there is flow out of the pump, the last check is to tap a fuel pressure gauge into the line downstream of the pump to check the pump output pressure, which should be at least 2.5 psi.
Good luck!
| Top |
jomo
Post subject: Posted: Thu May 05, 2005 1:05 pm |
Joined: Sun Jul 18, 2004 12:00 am Posts: 127 Location: Australia
_________________ Brake late & brake hard, jomo
Paso 906 Blue Paso 906 Silver Bultaco Metralla GT370 Custom Bultaco Metralla GT250 Bultaco Frontera 250 Mk.9 Suzuki RMX250
| Top |
[ 4 posts ] |
Users browsing this forum: No registered users and 16 guests |
