ducatipaso.org • View topic - To repair or part-out, that is the question
It is currently Fri Nov 14, 2025 10:15 am
 Post subject: To repair or part-out, that is the question
PostPosted: Fri Apr 29, 2005 4:52 pm
My brother was riding his 906 recently when his chain came apart. I got him home and had a new chain on in no time. Shortly after that incident he noticed oil drips under the bike, and now we found the chain has actually knocked a hole in the case at about the 11 o'clock position over the front sprocket. Instant automatic chain lube! My question is...is this repairable (would an epoxy repair work?) or should we start parting-out the old Duc? Any suggestions would be greatly appreciated. :confused:
PostPosted: Fri Apr 29, 2005 6:15 pm
ugh ... hole in crank case = bad
You can always try JB Weld; they say that stuff will tolerate almost anything, including cracked blocks, but ... I'd consider that a very temporary patch and nothing more - definitely not a 'solution'. How bad is the hole? Best bet would be find a salvaged bike or a similarly sized engine out of whatever, and swap case halves.
Lousy luck, that's for sure. Hope there was no get-off involved ... wallet damage stings, but at least you can walk away from it ...
1988 Paso 750 #753965
1997 Monster 750
PostPosted: Mon May 02, 2005 11:02 am
Yep - sounds ugly - however, I'd be taking the bike to a specialised engineering type shop, & seeing if they can weld it up. I once had to get the same thing done to the crankcase of a Yamaha trail bike I had, & it worked out fine, was relatively cheap, & did'nt leak.
Being a ex-bike mechanic, I've also seen such welding done at customer's request at times, & although the repair is traditionly not 'guaranteed' - it's often worth a go........
PostPosted: Thu May 12, 2005 11:31 am
Brake late & brake hard,
jomo
Paso 906 Blue
Paso 906 Silver
Bultaco Metralla GT370 Custom
Bultaco Metralla GT250
Bultaco Frontera 250 Mk.9
Suzuki RMX250
