ducatipaso.org • View topic - The Mega Paso Project
It is currently Fri Feb 27, 2026 2:39 pm
Post new topic Reply to topic  [ 38 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: The Mega Paso Project
PostPosted: Sun May 25, 2008 9:28 pm
PostPosted: Mon May 26, 2008 7:12 am
Hi All,
Fitting a ST4 engine to a 750 Paso - what a challenge indeed and some of us thrive on challenges!!!
Has anyone thought about building a 2 valve 851cc engine and using a 900SS motor as a basis? Steve Munro from Loudbike embarked on this avenue when he rebuilt a 750 F1 engine:
http://loudbike.blogs.com/photos/f1s_en ... index.html
This approach would probably be less time intensive but may end up being more costly due to the cost associated with building a one-off engine...
Mark
PostPosted: Thu Jun 26, 2008 11:08 am
I'm right in the middle of installing the 916 engine into this '88 Paso 750 frame. It is not a direct swap and it looks like I will have to modify the frame a little bit for horizontal head clearance, but it will not compromise the structural integrity of the frame.....especially once I get it rewelded to move the frame rail just a little bit. I've got all of the engine mounting lugs cuts down, but I need to trim the shrouding away from the lower engine mount on the engine cases to clear the lower rear suspension linkage mount on the frame. I'm getting close.
Here is an update on the engine installation with some pictures, so you can see my progress.
http://www.desmodemon.com/mega_paso/engine.html
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
PostPosted: Thu Jun 26, 2008 9:52 pm
Looks good! I have often wanted to do this project myself. GO DEMON! GO DEMON! GO DEMON! :thumbup: :lol: :cool:
1992 907ie Beauty. Custom high pipes, Pro Italia chip, Barnett performance clutch, Corbin Seat, Stainless brake lines. 35,000 miles. Owned since 1993.
PostPosted: Thu Nov 20, 2008 2:42 pm
Wow....it's been a while since I've had any time to mess with this project. Since my last post, I've done a valve adjustment and timing belt change on the wife's Monster and performed a bunch of work to other vehicles. This past weekend I did do some more filing on the engine cases to get it to clear the rear suspension mounting point on the frame that was hitting the case, but I have not test-fit the engine, again. I've got six days off starting next Tuesday, and I'm trying to motivate myself to get the engine installed in the frame during those days off from work.....well, work on the Megapaso and pull the swingarm off the wife's GSXR...maybe start the valve adjustment on the 748....change an exhaust gasket on the truck.....do some work to the other ST2..... :dunno:
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
PostPosted: Thu Nov 20, 2008 6:23 pm
:lol: seems, that You have very similar life, as i have here; too much work with too many bikes !!! This is horrible, because have to do also sometimes something else, that play with Ducatis.... :thumbup:
PostPosted: Sun Nov 23, 2008 5:27 pm
I spent some more time with it and now have the engine settled into the frame. I had to cut a small section of the frame to clear the horizontal head, but I have the engine bolted into the frame, now. I also see some more potential obstacles to overcome, but those will be later. The next thing I want to do is install the front and rear suspensions before getting the frame rewelded where I had to cut it, so that the frame will look nice and clean and unbutchered, again...
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
PostPosted: Sun Nov 23, 2008 5:50 pm
That motor looks really good in there!!!
So the frame was only cut on the one side to clear the cam? Do you have a picture from the front to see how much interference there is??
So far, so good!
PostPosted: Sun Nov 23, 2008 6:26 pm
I guess you will need to strenghten the frame to allow it to manage the extra power.
PostPosted: Sun Nov 23, 2008 7:29 pm
We shall see, does front tire hit to front sylinder/head.... :mrgreen:
Btw. whatkind electrics You have planned to Your project ????? :smoke:
PostPosted: Sun Nov 23, 2008 11:55 pm
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
PostPosted: Wed Mar 04, 2009 2:21 am
I haven't found the time to work on this projects in quite a while, so I took a couple of hours to assemble the bike with the front end and the rear suspension. I used the stock front forks since I traded the other triple clamps for five slightly used front tires. The rear suspension looks like it will work out great, and with the stock forks and 16" wheel, I don't think the front wheel will hit the horizontal head.....but I won't know for sure until I fully compress the front forks. Since I haven't updated my webpages on the project, here are some more pictures...
I think my next step is to take it back apart, get the frame rewelded where I had to cut it, and then start reassembling it....hopefully for good.
I have no idea when I'll do that, though. :wacko:
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
PostPosted: Wed Mar 04, 2009 11:27 am
Is the swingarm painted or anodyzed?
Ciao.
PostPosted: Wed Mar 04, 2009 1:47 pm
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
PostPosted: Wed Mar 04, 2009 3:11 pm
Will it be 16 or 17" frontwheel?
