ducatipaso.org • View topic - Plates to move foot pegs?
It is currently Mon Sep 29, 2025 10:03 am
 Post subject: Plates to move foot pegs?
PostPosted: Sat Dec 06, 2008 5:32 am
I'm getting old. My knees don't bend like they use to. Does anyone know about any way to lower the foot pegs or even move them forward. Maybe some kind of plate or adjustable rearset that will allow the adjustment of the foot pegs. Does someone make them commercially.
Thanks,
du907
 Post subject: Re: Plates to move foot pegs?
PostPosted: Sat Dec 06, 2008 10:33 am
Here is a type for ST2:
http://www.desmotimes.com/?utm_source=L ... esmo+Times.
Dunno if it fits but maybe easy to copy?
PostPosted: Sat Dec 06, 2008 2:36 pm
Good mail from Gert! :thumbup: ....But if want to go to race track, then such have take out from bike.... :mrgreen:
PostPosted: Sat Dec 06, 2008 2:48 pm
PostPosted: Sat Dec 06, 2008 3:00 pm
Frankie, You are looking "another girls"(at least sometimes!!!!), so, You are not getting old..... So, You DONT NEED SUCH AT ALL.... :lol:
PostPosted: Sun Dec 07, 2008 8:55 am
PostPosted: Sun Dec 07, 2008 10:16 am
Here was already 42 cm snow(one very big snowstorm), but near all is smelted away, so now only ab. 3 cm and dry/ -2 C.... Normally we get snow(what stays till end march) for christmastime. :thumbup:
PostPosted: Sun Dec 07, 2008 10:37 am
Hi du907, I lowered my pegs for touring by 2 inches. Made a big difference. Ground clearance is still ok as I think they were mounted quite high in standard trim. I rode a VFR750, which boasted more leggroom according to the write ups, and it felt as good if not better than the Honda.
The left side, I made a plate using the original holes to mount it and then drilling 2 lower holes.
The right side, i made a peg bracket from scratch - bit of work! This also ment cutting a foot peg and re-mounting it to my fabricated piece.
The main consideration making all this, was the clearance to the staintunes. Which, in the end worked out no worries.
And of course I made some small adjustments to the gearshift linkage and footbrake actuator, but nothing to dramatic.
Hopefully this has helped, you maybe able to improve on this idea..................
PS. I have pictures if anyone is interested, but not sure how to attach them?
PostPosted: Mon Dec 08, 2008 1:23 am
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
PostPosted: Mon Dec 08, 2008 4:09 pm
Great response everyone!
Desmo_Demon, davo, do you have pictures of your bikes? I figured an alum. plate with tappered screwheads so the original plate mounts could be installed with the origianl screws and moved to the appropriate position that would be determined. Adjustments for the shifting rod and brakes would have to be made as well as clearence from pipes etc.
PostPosted: Tue Dec 09, 2008 12:26 pm
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
PostPosted: Thu Dec 11, 2008 12:41 pm
Hi du907,
Follow up to my privious reply: Footpegs lowered by 50mm or 2 inches.
I just noticed the entry by jcslocum `How to insert pictures`, so here they are.
This bracket I made, used the original mounting holes. It has a fold on one edge, just for strength. The gear shifter was adjusted to suit my usual position by adjusting the length of the connecting rod. From memory, I may have slipped the connecting rod bracket off the spline to get the shifter in the ball park first.
Also after I did this, another problem arose, the gear shifter arm hit the side stand.
So I made a side stand which tucked in closer to the frame rails.
I made it slightly longer, as I felt paso`s (owned 2)and 907`s (on my second one) allways leant over too far anyway.
This side was also a challenge. As the rear brake actuator was already close to the staintune, I made a `lowered foot peg`.
This involed starting from a solid block of steel and cutting a slot in the middle for the spring. Then i just shaped it similar to the original. To lower the peg itself, i welded on a piece of stainless steel (so it wouldn`t flex) to the block.
This was when I bought a spare foot peg off ebay.
I cut part of the peg off, where the spring goes through, just befor the rubber part. It had to cut at the correct angle to sit write on the flat piece of stainless.
I neally stuffed this part of the operation up........
The cut off peg was attached to the stainless extension by some metal screws drilled and tapped into the aluminium.
Another problem arose. To lower the foot brake arm to suit my usual position. I wasn`t going to achive this with the small adjustment on the actuator pin inside the slave cylinder. So I made a slightly shorter pin. I just copied the orginal using a piece of stainless rod the same diameter.
Sounds like a lot of work............It was.
But it was a labour of love!
Hope this helps to give you some ideas.
PostPosted: Fri Dec 12, 2008 2:25 pm
Great pics. Exactly what I was looking for. Now I will have to come up with a similar way to fabricate my own. I especially like the way you did the left side, gear side. That is basically what I had envisioned it. I was thinking of using a aluminium plate there but the basic idea is the same.
Du907
PostPosted: Fri Dec 12, 2008 8:08 pm
davo, tell to us more about Your wheels !!! Are they polished, or what??? What method You have used???? ..very courious! :)
PostPosted: Fri Dec 12, 2008 10:40 pm
Hi Antti, the wheels were polished when I bought the bike. According to the chap, they were just stripped and polished.
How they were initially polished, I`m not sure. He said he had a friend who polished wheels.
Every so often I use an metal polish on a rag to clean them up. But they generally stay quite shiny.
I had intended to have them repainted back to orginal condition, but I still can`t make up my mind which I prefer, painted or polished.
I used to be unsure, but now now I`m just undecided.............................
