ducatipaso.org • View topic - Marelli Ignition Needed
It is currently Sun Nov 01, 2026 4:51 am
 Post subject: Marelli Ignition Needed
PostPosted: Sun Apr 24, 2005 1:05 am
PostPosted: Mon Apr 25, 2005 3:48 pm
I doubt you find new units from anywhere.
Certain Fiat cars used that Digiplex II system for ignition, like Fiat Tipo.
If you can find Fiat cars from "junk yards", you also might find Digiplex system.
BR Mika :thumbup:
PostPosted: Thu Apr 28, 2005 4:52 pm
Digiplex ll ignitions were fitted to Fiat cars? that is good news. You should be able to buy a new one from a Fiat Parts Dealer then.
PostPosted: Thu Apr 28, 2005 7:38 pm
PostPosted: Thu Apr 28, 2005 7:57 pm
PostPosted: Mon May 02, 2005 11:22 am
Interesting to hear about the cross referencing to Fiats etc. Are they going to have the right advance curve? Also, from playing around with mine, I found they have 2 terminals to trigger the spark, one for each cylinder.
Is the bike going onto 1 cylinder? At 17,000 km, mine had a cracked circuit board. A television technician mate fixed it. I still had troubles with the soldered joints over the years, so I finally bought a new unit from Silent Hektik. It came with coils and spark plugs. Now it is totally reliable, but , at a price. $1100 Aus. you can choose the advance curve to suit your requirements. I haven't had a go at the other curves yet because I am still fiddling with jetting. The unit is good, but I think the original is just as good when working properly.
What are the symptoms? Going onto 1 cylinder all the time? or intermittently?
Good luck with it.
Brake late & brake hard,
jomo
Paso 906 Blue
Paso 906 Silver
Bultaco Metralla GT370 Custom
Bultaco Metralla GT250
Bultaco Frontera 250 Mk.9
Suzuki RMX250
PostPosted: Mon May 02, 2005 2:35 pm
I know, that there is one "eprom"(if remembering right, its NOT removable) inside Marelli Digiplex box, so it might be, that those ignition curves, of Fiat cars dont fit??? Have anybody tried?
finnpaso
907IE
750Paso
PostPosted: Wed May 04, 2005 1:30 am
Thanks Jomo
The symptoms:
First let me say that some time ago the ignition had cut out intermittently and I diagnosed it to a faulty connection in the switch.
In the present case the bike runs fine until warm. Then when running down the road at a steady throttle is seems to hesitate. The hesitation disappears on acceleration or when going uphill. Then the bike starts to miss entirely on the front cylinder, sporadically kicking in.
At first I thought it was fuel but a strobe on the spark wires showed it was electrical.
If I can get my hands on a shop manual with the sensor calibrations a friend with an electrical bent will help. Right now my strong inkling is the box and thus the inquiry.
Any help would be appreciated.
Kundune
PostPosted: Wed May 04, 2005 2:12 am
I have the Ducati workshop manual, it is not one for the novice as it is aimed at the ducati mechanic, I will have a look & if I find it scan & upload it. you can get teh Workshop manual from Gowanloch Ducati in Sydney
http://www.ducati-gowanloch.com
check them out here, if you email the problem to them they also get back with excellant feedback very fast.
I will check my manual & see if I can sort that damn scanner of mine :thumbup:
Redpaso
PostPosted: Thu May 05, 2005 12:46 pm
jomo
Paso 906 Blue
Paso 906 Silver
Suzuki RMX250
PostPosted: Thu May 05, 2005 2:22 pm
PostPosted: Thu May 12, 2005 11:03 am
jomo
Paso 906 Blue
Paso 906 Silver
Suzuki RMX250
 Post subject: marelli ignition
PostPosted: Fri Jun 16, 2006 8:46 am
I have 3 magneti marelli digiplex ignition that work. They are not new, buth I can asure you they work.
My price is 150 euro/piece (the same as I bought them, out of sympaty for the Paso). Please react if interested. I'm a Belgian.
Greetings,
Pasofreak.
 Post subject: Re: marelli ignition
PostPosted: Fri Apr 27, 2007 1:39 pm
 Post subject: Re: marelli ignition- are these still available?
PostPosted: Mon Apr 30, 2007 12:09 pm
