It is currently Sun May 03, 2026 3:52 pm
| Author |
jpiepho
Post subject: WTD 907 swing arm Posted: Wed Jan 07, 2009 4:47 pm |
Looking for a swing arm in the US to fit a 91 paso.
| Top |
Post subject: Re: WTD 907 swing arm Posted: Wed Jan 07, 2009 11:36 pm |
| paso grand pooh-bah |
I have one for a 906, needs to be cleaned up and anodized, has some battery acid stains but structurally excellent
| Top |
jpiepho
Post subject: Re: WTD 907 swing arm Posted: Thu Jan 08, 2009 7:59 pm |
How much do you want for it? I don't mind cleaning it up butI don't know about how to go about getting it annodized.
| Top |
Kurt
Post subject: Re: WTD 907 swing arm Posted: Thu Jan 08, 2009 8:52 pm |
Joined: Fri Mar 21, 2008 8:57 pm Posts: 194 Location: Arlington, Massachusetts USA
A little off thread, since it's not about your swingarm, ... I was thinking of getting mine polished -- has anyone done that? Might send the footpegs out, too. Not original, I know, but I like the look of slowly fading polished aluminum ... (to each his own, there's no accounting for taste, etc.)
_________________ - Kurt
| Top |
persempre907
Post subject: Re: WTD 907 swing arm Posted: Thu Jan 08, 2009 10:48 pm |
| Top |
Post subject: Re: WTD 907 swing arm Posted: Thu Jan 08, 2009 11:30 pm |
actually anodizing itself is not that expensive or difficult if you have access to a good voltage source( right kind of battery charger will do) but it would certainly be easier to have it polished and sealed with a good durable clear coat. On the subject of the 906 swingarm I have, I would prefer to barter but we can work something out in our mutual interest if you like Oh I am partial to beaded aluminum finishes and grained stainless btw,bevel heaven has canisters you can add to your bike to prevent battery acid stains to begin with...........
| Top |
jpiepho
Post subject: Re: WTD 907 swing arm Posted: Fri Jan 09, 2009 1:09 pm |
I don't mind a barter but my selelection of paso spares is limited. I've got an original tail light & rear turm signals, a cracked but repairable mirror from a garage tip over & a used set of clutch plates that I think wil work if re-surfaced. Of course I need to look into the compatabilty of the 906 swing arm.
| Top |
Post subject: Re: WTD 907 swing arm Posted: Fri Jan 09, 2009 2:05 pm |
forget that. It doesn`t make any sense to put a 750/906 swingarm in a 907ie. It would fit but it`s shorter as it`s not made for 17" wheels. Rear axle diameter is also different (20mm on 750/906, 17mm on 907ie) Keep the mirror or have someone repair it if it`s an original clip-on one as it`s quite valuable.
| Top |
jpiepho
Post subject: Re: WTD 907 swing arm Posted: Fri Jan 09, 2009 2:41 pm |
Ok, thanks for the advice... I'll keep looking, if I can't find one maybe I can find someone to repair the damage to mine caused by the loose sprocket carrier bolts.
| Top |
Kurt
Post subject: Re: WTD 907 swing arm Posted: Fri Jan 09, 2009 3:52 pm |
| Top |
Post subject: Re: WTD 907 swing arm Posted: Sat Jan 10, 2009 11:32 am |
http://www.focuser.com/atm/anodize/anodize.htmlall about anodizing. If you decide to replace your 907 swingarm I am interested in your damaged one in case I decide to go 17 inch
| Top |
persempre907
Post subject: Re: WTD 907 swing arm Posted: Sun Jan 11, 2009 9:38 am |
| Top |
kalli
Post subject: Re: WTD 907 swing arm Posted: Wed Feb 11, 2009 3:56 pm |
Joined: Tue Mar 14, 2006 12:00 am Posts: 47 Location: greece
Hallo everybody,
i have a 907 paso swinging arm for sale. if anybody is interested late me know.
thanks kalli
| Top |
Users browsing this forum: No registered users and 13 guests |
