ducatipaso.org • View topic - clutch stack up on my 750(just shoot me and be done with it)
It is currently Mon Mar 09, 2026 5:55 pm
 Post subject: clutch stack up on my 750(just shoot me and be done with it)
PostPosted: Sat Jan 10, 2009 8:04 pm
I know there are a lot of posts on this subject, but I'm still not sure. I took off my clutch carefully so I could match everything up, the problem is the 2 steel disks that have a dot on them. the dots must be there for a reason but mine seem to be in random places (are there specific locations for these 2 disks? (location and orientation, facing in or out?) and is this right to put the notches on the steel disks 90 degrees off set from each other? these were in random locations on mine when I removed them. it may not be critical but I would like to make sure everything is exactly right and of course the manual might as well be written in Italian, oops I guess it is, unfortunatley its the english version that doesnt make much sense
 Post subject: Re: clutch stack up on my 750(just shoot me and be done with it)
PostPosted: Mon Jan 12, 2009 3:39 am
Ok I'm just dumb, I found the clutch stack up thread on FAQ sorry
PostPosted: Tue Jan 20, 2009 12:40 am
That's what it's there for!
Glad you found it before you had time to shoot.
PostPosted: Sun Jan 25, 2009 10:46 pm
FYI, The secret to a happy clutch is to leave ~5mm clearance in the pack with the springs out. If you leave more clearance, it will slip. Less clearance and it will stick. You need extra plates to shim it in or out.
http://www.guzzitech.com/Bimotacagiva/a ... lutch.html
ed
PostPosted: Mon Jan 26, 2009 3:46 pm
I assume you mean I should assemble clutch on to motor without springs and measure 5mm play up and down with the discs???
PostPosted: Tue Jan 27, 2009 1:48 am
You got it. It's that easy.
ed
PostPosted: Tue Jan 27, 2009 4:29 pm
thank you everyone for all the information, its mind boggling how much information was sent my way. The local duc dealer confirmed that I have the right clutch, now I will check total stack up height, clutch pack clearance when installed without springs, then I'll install everything start the bike up , close my eyes and let the clutch out. If I dont post again then I'm probably dead thanks John
