It is currently Sun Sep 28, 2025 11:17 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 4 posts ]
 Post subject: No Spark
PostPosted: Mon Jan 19, 2009 6:39 pm
What do i do Battery is good and new
Fuel is good pump primes?????
 Post subject: Re: No Spark
PostPosted: Mon Jan 19, 2009 6:59 pm
I thought you had no ECU :huh:
PostPosted: Tue Jan 20, 2009 4:03 pm
It might help to put in a bit more of a description of the problem...
like was the bike running and then just "stopped dead" or began misfiring or was it bought "not running" and you're trying to get it started...or maybe a friend borrowed it...
if you mean "no spark" suggest to:
1. check the kill switch is set to "RUN"
2. pull a plug and EARTH it to frame, then test...
3. check power to both coils
4. check power to both ignitors (be careful with earth)
5. check crank timing sensors
if you mean "won't start"? check the compression...
PostPosted: Tue Jan 20, 2009 6:17 pm
also check each coils reisistance, I just had one crap out on me.............
