ducatipaso.org • View topic - cheap fuel pressure problem fix
It is currently Sat Mar 07, 2026 12:05 am
 Post subject: cheap fuel pressure problem fix
PostPosted: Wed Jan 28, 2009 7:15 pm
i may have mentioned this before but the fuel pressure on all the weber equiped models can be easily adjusted. in the fuel return line there is a carburator main jet located about in the middle of the fuel line that is attached between the t-fitting and the fuel tank. it;s even in the parts catalog. now i have never had to do this because i switched to mikunis before i discovered the jet while inspecting the fuel lines so i don't know how much affect changing the jet will have but it's pretty obvious the intent of the design. i have looked through all the old tech notices i got from ducati and there was no mention of this even though the problem was known back then though that doesn't surprise me one bit. ducati can get a little cryptic sometimes. anyway, if anybody tries this or has already post the results, i would like to know. oh, i think the ss models have this jet too. blaster
 Post subject: Re: cheap fuel pressure problem fix
PostPosted: Fri Jan 30, 2009 1:37 am
Blaster,
I had heard this before, but since my bike was so badly bastardized, I could never confirm nor deny that it was true. Opening up that return line would surely help. I don't know why they thought they needed that much pressure to a carb with a float bowl. The simple fact of having a couple inches of head of pressure works for every bike I have ever seen. I have never run into a fuel starvation problem without the restrictor in place. Makes you wonder what problem they were trying to solve.
Maybe it was supposed to be in the feed line and not the return line.
I also don't know why a carbureted bike needs a fuel pump either.
Easy things to fix, but strange engineering.
PostPosted: Fri Jan 30, 2009 6:20 am
Users browsing this forum: No registered users and 32 guests
