ducatipaso.org • View topic - Body panels questions
It is currently Fri May 01, 2026 5:38 pm
 Post subject: Body panels questions
PostPosted: Sat Feb 07, 2009 2:12 am
Good evening friends!
Need some help with the following;
1. Any place I can buy the right hand side fairing for my '92 907? (preferably new)
Any aftermarket or "secret" suppliers?
2. I have two fairly large bubbles (look like air bubbles) around the gas tank door. I checked inside the tank and
around the door areas and there doesn't seem to be evidence of rust.
I think the only way to fix this would be to repaint the tank, any other ideas, suggestions or advice?
Pics of the "bubbles" >> http://s122.photobucket.com/albums/o272 ... 2006Feb09/
Thanks!!
1992 Ducati 907 IE
1993 Ducati 750 SS
2006 Harley Davidson Sportster
2008 Harley Davidson ElectraGlide Classic
 Post subject: Re: Body panels questions
PostPosted: Sat Feb 07, 2009 2:27 am
http://www.airtech-streamlining.com/euroz/d2paso.htm
These guys advertise new 907ie panels, the side is priced around $200.00. I can't attest to their quality but the web site has some pix of what look like nice work. They're located in Vista, Ca, and list a significant number of bikes for which they make replacement parts. Standard disclaimer: I don't work for Airtech, don't know anyone who works there, don't receive any kickback from them and have never been a doctor or a lawyer nor have I played the part of a doctor or lawyer on TV.
robert
'93 Ducati 907ie
'75 Norton 850 Commando
'98 BMW K1200RS
'85 VW Vanagon (to haul parts for the bikes...)
PostPosted: Sat Feb 07, 2009 2:51 am
the paint issue is tricky...obviously there is something bubbling the paint - possibly permeation from fuel spills?
depending on how fussy you need the repair (and we all want perfection) I'd leave it to experts, but it should touch & feather OK. Colour match and cutting will be critical...
my understanding with Airtech panels is that the outer appearance is matched BUT that any inner profiling is not - basically that the piece is sprayed into a one-sided pattern.
this shouldn't matter too much on the side panels...and $200 is not too bad for a price...
PostPosted: Sat Feb 07, 2009 3:50 am
Thanks for the site on the panels and info, much appreciated.
I believe the bubbles are the result of overfilling the tank, some fuel seepage under the paint, can't blame no-one except myself :suicide:
It's really a dilemma as the paint is original and in pretty good shape except for the damned bubbles, hate to end up messing the entire bike trying to fix something minor, still, as we all know where does the eye go as soon as I'm near the bike? to the bubbles of course...8]
Also the issue of getting the correct paint and primer, the hassle of getting a reputable painter ...ah, decisions, decisions :smoke:
Anyway thanks again for your insights!
1992 Ducati 907 IE
1993 Ducati 750 SS
PostPosted: Sat Feb 07, 2009 10:20 am
Another issue with Airtech: all the panels are sold without any hole for the bolts, so you have to drill the panels by yourself matching the holes on the tank and the side fairings.
For the air bubble... First, I'd try to touch the paint...
Good luck :thumbup: :thumbup: :thumbup: .
PostPosted: Sat Feb 07, 2009 12:36 pm
+1 on the hole drilling, probably easy if you have the proper tools, steady hands and "courage" though, risky nevertheless.
I assume when you say "touch the paint" you mean touch-up or spot repair, correct?
Thanks .. :thumbup:
1992 Ducati 907 IE
1993 Ducati 750 SS
PostPosted: Sat Feb 07, 2009 1:40 pm
PostPosted: Sat Feb 07, 2009 1:46 pm
Sam ...any ideas/thoughts on the paint bubbles? Any "racers" tricks, old wives tales? :beer:
1992 Ducati 907 IE
1993 Ducati 750 SS
PostPosted: Sat Feb 07, 2009 1:55 pm
Last edited by samandkimberly on Sun Feb 08, 2009 2:01 pm, edited 1 time in total.
PostPosted: Sat Feb 07, 2009 2:04 pm
Wow! I thought about the same technic but didn't know how to go about it ...many thanks Sam!
1992 Ducati 907 IE
1993 Ducati 750 SS
PostPosted: Sat Feb 07, 2009 2:14 pm
PostPosted: Sat Feb 07, 2009 2:18 pm
not a problem persem, just didn't want to miss any possible option you might have been referring to, rgrds! ... :beer: :beer:
1992 Ducati 907 IE
1993 Ducati 750 SS
PostPosted: Sun Feb 08, 2009 5:10 am
if you do the adhesive spot repair you won't have problems with colour matching
you'll need to cut back with about 1200 grit wet&dry
then...
get cornflour (dry) and do the final polish.
RollsRoyce were always cut&polished with cornflour...it blends into micro-scratches and fills.
many paints had cornflour as a constituent.
PostPosted: Sun Feb 08, 2009 7:01 pm
PostPosted: Sun Feb 08, 2009 8:09 pm
yep, "cornstarch" it is, I remember this trick from my old muscle car days ...8]
1992 Ducati 907 IE
1993 Ducati 750 SS
