ducatipaso.org • View topic - Paso repair update
It is currently Sun Mar 08, 2026 2:27 am
 Post subject: Paso repair update
PostPosted: Sun Feb 15, 2009 10:33 pm
I've had the rear wheel off the Paso to measure up the rear brake caliper and disc. It appears that the disc mount isn't the proper part and mounts the rotor disc too far to one side. This caused the bolts that the mount the rotor to cut into the caliper mounting bracket and ripped it up pretty bad.
This pic shows just how far off the disc is. The split in the caliper should be right in the center of the disc.
I have a new caliper mount and just need to have the disc mount machined down to the proper dimension.
 Post subject: Re: Paso repair update
PostPosted: Mon Feb 16, 2009 1:02 am
there is only going to be a lot more of that sort of thing,as this group of ducati pass on to collector land and the land of unobtainium and persistant intergalactic backorder draws ever nearer.Good thing you developed them thar tractor skill now ain't it? :-P
PostPosted: Mon Feb 16, 2009 2:29 pm
This was probably just done out of ignorance by the installer a long time ago. They are Technomagnesio magnesium wheels and the wrong adaptor was installed to hold the brake disc.
The wheel, tire and disc weights 25 lbs.
BTW I didn't do the install. I bough the bike this way.
PostPosted: Mon Feb 16, 2009 3:37 pm
Thiskind can happen, if u are not 100% sure about offsets... :,(
PostPosted: Mon Feb 16, 2009 5:48 pm
pros at work - scary.
PostPosted: Mon Feb 16, 2009 6:22 pm
I think everyone here knows it was not you :thumbup: :thumbup: :thumbup:
PostPosted: Mon Feb 16, 2009 6:34 pm
I wonder that that wasn`t noticed before. When the rear was jacked up one should`ve noticed immedeately that the wheel didn`t turn unless it did at the beginning and somehow slowly moved to the right.
PostPosted: Mon Feb 16, 2009 7:27 pm
Strange things happen sometimes.... :smoke:
PostPosted: Mon Feb 16, 2009 11:27 pm
PostPosted: Tue Feb 24, 2009 9:14 pm
I've had the disc mount machined down so that the bolts heads will no longer hit the caliper bracket. It's interesting just how close certain things run. The caliper to bolt head clearance is really small but when correct, quite safe. All that we removed was 2mm from the flange face by a local machine shop that does really superior work.
These 2 pics show where and how much was removed. The 6 tabs were black before machining. I chose to remove the 2mm from the outer ring since the material was thicker than the smaller mount.
Once it's installed, I'll shoot some more pictures to show the fit.
PostPosted: Wed Feb 25, 2009 2:19 am
PostPosted: Sun Mar 08, 2009 10:57 pm
I have installed the machined rear disc mount and it fits much better. The rotor is in the right spot and the clearance between the rotor bolts and the caliper bracket is about 2.5mm.
Before
After
Now to get on to the other tasks at hand!
PostPosted: Sun Mar 08, 2009 11:18 pm
:thumbup:
PostPosted: Tue Mar 10, 2009 1:41 pm
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
PostPosted: Mon Mar 23, 2009 11:20 am
No repair update today but I'm pissed at myself. I drained some oil from one of the cars and set it onto the side of the stand that the Paso is up on. I was being lazy and didn't pour the oil into the storage container. I then backed the tractor into the barn and hit the edge of the pan and knocked it off the stand. I didn't notice so I had 4 quarts of shitty old oil sitting on my new concrete floor for week!! :-( I had to spend 2 hours cleaning it up instead of working on the Paso.
The battery is toast by the way. 4 hours on the charger and 3.6 volts. Damn. :-/
Users browsing this forum: No registered users and 22 guests
