ducatipaso.org • View topic - Cleaning/Maintenance of stock exhaust pipes on Paso 750
It is currently Sat Jun 20, 2026 6:47 pm
 Post subject: Cleaning/Maintenance of stock exhaust pipes on Paso 750
PostPosted: Wed Jan 21, 2009 3:43 am
:wacko: I tried to use the search engine but did not find what I was looking for regarding the exhaust pipes on my 1987 Paso 750. I managed to locate a new set of original stock pipes but they appear to need some type of cleaning. Can someone recommend the best way to clean and maintain the original pipes that came on a Paso? They are coated or painted and I don't want them to rust or be damaged in the cleaning process. Someone recommended Baby oil but I'm not sure...any help would be greatly appreciated.
 Post subject: Re: Cleaning/Maintenance of stock exhaust pipes on Paso 750
PostPosted: Wed Jan 21, 2009 5:19 am
As far as the exterior, It was starting to pit and slightly rust. I sand blasted the slip on's and had them powder coated by a friend. He used a coat that was rated for hi temp. Came out beautiful (looks original) and has maintained it's look.
PostPosted: Thu Jan 22, 2009 5:26 pm
the finish is called black chrome. I just polish them to get off initial rust and then wipe them down with a rag after spraying some WD40 on it. I do this specially on all weldseams. The oilfilm will burn in and after a few months I will repeat treatment. Worked fine for me on different bikes.
PostPosted: Fri Jan 23, 2009 12:48 am
I painted my header pipe with black Hi Temp paint. Looked great and held up well.
PostPosted: Mon Jan 26, 2009 5:41 pm
Horse,
My mufflers had, in some areas but not all over, very small spots of rust beginning to form. I had success polishing these sposts out with "0000" grade (4 zeroes) steel wool. The steel wool is oil impregnated on so it doesn't rust on the store shelf and that impregnation seems to be just the right amount to coat and lubricate the mufller surface as you scrub away. Try an inconspicuous area first and be prepared to use ALOT of elbow grease. The steel wool also removed a lot of old-age tarnish and really made the mufflers shine. Once finished, I wiped them off with a clean rag and applied a coat of wax.
Tom
PostPosted: Tue Jan 27, 2009 11:24 am
I bought a couple of black used 907 mufflers.
They have a cylindrical shape, as the last 906 and some 750 I saw somewhere.
They were on a shelf for long time and now they are black dull.
Do you think it's enough to polish them?
PostPosted: Wed Jan 28, 2009 2:14 am
Francesco,
If the mufflers have the same "black chrome" finish that my 750 has, they should clean up nicely with the 0000 grade steel wool. Try starting someplace you won't easily see first just to make sure the cleaned area looks good to you. If you check out my posting titled "Eye Candy" elsewhere, you'll see how my mufflers look.
Tom
PostPosted: Wed Jan 28, 2009 10:51 am
Many thanks Tom,
I remember very well the topic about your nice bike.
I think the look of the paint has to be polished and not dull.
So, I'll try with the steel wool.
PostPosted: Wed Feb 18, 2009 3:26 am
I've bought at a supermarket some some black polish for a furnace.
I'ts heat resitand and give a nice shine.
My silentiums look brand new now!
PostPosted: Thu Feb 19, 2009 3:54 pm
PostPosted: Thu Feb 19, 2009 10:59 pm
Its a black polish for cast iron furnaces who burn on wood,gas etc...
PostPosted: Thu Feb 19, 2009 11:11 pm
See Those Silentiums shine!
PostPosted: Thu Feb 19, 2009 11:52 pm
Thanks Frank. Your Paso looks great.
PostPosted: Fri Feb 20, 2009 8:10 am
