ducatipaso.org • View topic - aftermarket springs
It is currently Fri Mar 06, 2026 9:15 pm
 Post subject: aftermarket springs
PostPosted: Sun Feb 22, 2009 7:35 pm
Aftermarket springs.
Which type of after market springs(suspension) are the best? I use Hyperpro others ohlins and you?
Duncati.
 Post subject: Re: aftermarket springs
PostPosted: Sun Feb 22, 2009 7:48 pm
I havent ever heard, that Öhlins make springs to M1R forks... :thumbup: But Öhlins support ST series forks and Paso 750 rear schock(STILL!!!) :smoke:
PostPosted: Sun Feb 22, 2009 9:37 pm
I did not mention front or rear only, i chose hyperpro for the simple reason that one can balance front and rear from the same company, a good example is tyres, would you use 2 different types? Still everyone is entiltled to their opinon, thank god. :smoke:
Take care on the black stuff, :thumbup:
Duncati
PostPosted: Sun Feb 22, 2009 11:26 pm
Pretty sure you can get a spring f rear Marzocchi from Öhlins.
PostPosted: Mon Feb 23, 2009 7:39 pm
Paso Öhlins have TOTALLY different spring, than Marzhocci have... :smoke:
PostPosted: Mon Feb 23, 2009 8:59 pm
