ducatipaso.org • View topic - Alternate wheels for the 907s
It is currently Sun May 03, 2026 9:57 pm
Post new topic Reply to topic  [ 36 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: Alternate wheels for the 907s
PostPosted: Sun Feb 01, 2009 11:50 am
Ok, so rims that fit the 1990-1993 916s, 900SS, 851s, 888s, ect. should fit the '92 907, correct?
Basically rims for two sided swingarms, right?
Another issue I want to avoid is the need for modifications, spacers, re-drilling, ect.
:mrgreen:
1992 Ducati 907 IE
1993 Ducati 750 SS
2006 Harley Davidson Sportster
2008 Harley Davidson ElectraGlide Classic
PostPosted: Sun Feb 01, 2009 12:15 pm
from 916/748 only front rim will be useable. All other bikes you listed (incl. Monster) basically had the same 3 spoke rims in different colours. Exception the 5 spoke Marchesinis (ie Monster 900S) and 3 spoke Marvics (early Superlights). Beware that there could still be some small differences ie a 17 or 20mm front wheel axle or a specific sprocket carrier on the Marvic rims (as far as I know also 16" and 17" Marvics are different in this point)
If you go for aftermarket wheels for one of these models things will become probably more expensive than adapting wheels from another bike investing also in some modification.
PostPosted: Sun Feb 01, 2009 12:49 pm
Hi Paso 750,
Yes I know PVM wheels. They're nice, but not what I'm looking for. It's the Dymag 5 spoke magnesium with carbon rim or nothing.
I already have 2 sets of wheels. one of them are 3-spoke magnesium Marvic ones, coming from a 888 racer and were used as rain wheels. the width of the rear wheel is 6", which may be a little wide for the 907
The other sets is for my 900 project, which is laying around for a few years.
But thanks anyway,
Ducbertus
PostPosted: Sun Feb 01, 2009 3:00 pm
Have to remind some things now:
1. You might have problems, if You try fit wider, than 5.5" rim to 907.... I have noticed, that if i use 180 rear tire(like i normally use!), then there is only VERY small distance between tire and chain and if then chain is not allways tightened to right level, then it start to hit to side of tire making harm there....
2. If U add such too wide rim, You have to be 100% sure about chain line !!!
3. Is it wise to put so much money to get such "nice looking", (but in technical terms, "NOT SUITABLE") wheels to 907 ??? :thumbup:
PostPosted: Sun Feb 01, 2009 3:05 pm
PostPosted: Sun Feb 01, 2009 3:25 pm
PostPosted: Sun Feb 01, 2009 3:30 pm
Maybe easier if you specified what you´re looking regarding looks etc?
PostPosted: Sun Feb 01, 2009 4:50 pm
PostPosted: Sun Feb 01, 2009 11:51 pm
Thx, Antti! :beer:
PostPosted: Mon Feb 02, 2009 9:17 am
PostPosted: Mon Feb 02, 2009 9:48 am
PostPosted: Mon Feb 02, 2009 6:08 pm
So, back to the basic question.
every wheel will fit as the diameter of the axle is the same, the width of the wheel between the members of the swingarm in the axle area is the same. than you have to check the chain-line between the sprockets. if that's oke too, I think you're fine
Ducbertus
PostPosted: Mon Feb 23, 2009 8:38 pm
'91 907ie (Red)
'93 907ie (Red)
'93 907ie, w/ worked engine (Red)
'07 1098S (Red)
'07 MV Agusta F41000R
'82 Kawasaki KZ1100 Spectre (Wine/Black)
PostPosted: Mon Feb 23, 2009 8:48 pm
PostPosted: Tue Feb 24, 2009 1:10 pm
'91 907ie (Red)
'93 907ie (Red)
'07 1098S (Red)
